PG3 node servers mostly offline
I just purchased (after doing the trial) the Tesla node.  It would not connect.  I tried rebooting PG3, then the entire Polisy.  Now a bunch of my nodes won't connect.  I try to reboot them, and it says they aren't running.  For a couple seconds it lists running time  . . . 1, 2, 3 seconds, then it switches to saying not running.  Same thing with Blue Iris, Roomba, Push.  The only PG3 nodes that are working are iTach and Backup.
What version of PG3 are you running?
What's in the node server logs that aren't starting (if there is any log)
What in the PG3 log?
Wait, it took a long time and a windows error message saying page unresponsive, but it did finally give me a log.
Here is some of it.
8/16/2022, 18:17:26 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:17:30 [pg3] warn: MQTTS: keepaliveTimeout: pg3frontend_x16kS
8/16/2022, 18:17:30 [pg3] error: MQTTS: clientError: pg3frontend_x16kS keep alive timeout
8/16/2022, 18:17:30 [pg3] info: MQTTS: Client Disconnected: pg3frontend_x16kS
8/16/2022, 18:17:30 [pg3] debug: Client pg3frontend_x16kS unsubscribed from udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76
8/16/2022, 18:17:30 [pg3] debug: Client pg3frontend_x16kS unsubscribed from sconfig/#
8/16/2022, 18:17:30 [pg3] debug: Client pg3frontend_x16kS unsubscribed from spolisy/#
8/16/2022, 18:17:31 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:17:31 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:17:36 [pg3] info: MQTTS: Client Connected: pg3frontend_x16kS
8/16/2022, 18:17:36 [pg3] debug: Client pg3frontend_x16kS subscribed to udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76
8/16/2022, 18:17:36 [pg3] debug: Client pg3frontend_x16kS subscribed to sconfig/#
8/16/2022, 18:17:36 [pg3] debug: Client pg3frontend_x16kS subscribed to spolisy/#
8/16/2022, 18:17:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_x16kS has published message on udi/pg3/frontend/isy/admin to broker pg3_broker
8/16/2022, 18:17:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_x16kS has published message on udi/pg3/frontend/system/admin to broker pg3_broker
8/16/2022, 18:17:36 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"425f2619-2764-4471-8f6d-1d739c4d6ec7","uuid":"00:21:b9:02:38:63","token":"!*!-rTR*Rlm%A*DB","name":"isylink","nsid":"","expires":0,"nickname":null,"profileNum":1,"timeAdded":1649262681253,"timeStarted":null,"timeModified":1649262681254,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"ec934f8e-544d-471f-8d88-fda857ece038","uuid":"00:21:b9:02:38:63","token":"XHiyu*EgnWke-MWV","name":"2","nsid":"","expires":0,"nickname":null,"profileNum":2,"timeAdded":1649262681278,"timeStarted":null,"timeModified":1649262681278,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"af39d9b8-cd5a-4f5c-b605-e905eaa7697f","uuid":"00:21:b9:02:38:63","token":"nH)O-rOue=5tfrw)","name":"ISY Portal","nsid":"","expires":0,"nickname":null,"profileNum":3,"timeAdded":1649262681301,"timeStarted":null,"timeModified":1649262681301,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"f6e82cc1-ec9c-4b36-83ec-da08eeb226d8","uuid":"00:21:b9:02:38:63","token":"vrcnCQX5GxTOlZ-x","name":"BlueIris","nsid":"bffcf8d8-f0e7-4e64-a662-1ca53314525a","expires":0,"nickname":null,"profileNum":4,"timeAdded":1651780396101,"timeStarted":0,"timeModified":1660690909055,"version":"2.0.2","branch":"master","url":"https://github.com/UniversalDevicesInc-PG3/udi-blue-iris-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_4","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"blue-iris-poly.py","shortPoll":2,"longPoll":60,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":"controller","status_driver":"ST","orderId":null,"store":"Production","dbVersion":1,"nodeCount":18,"notices":{}},{"id":"efc170e6-ef7b-4ae7-8535-0b550bc1497b","uuid":"00:21:b9:02:38:63","token":"Hp0b)Tb/b)bHAvBn","name":"HarmonyHub","nsid":"","expires":0,"nickname":null,"profileNum":5,"timeAdded":1649262681408,"timeStarted":null,"timeModified":1649262681408,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"5e7fdc5d-a13b-4262-9dda-85820d4ff9ca","uuid":"00:21:b9:02:38:63","token":"%*zcuq%ccBKIeE4a","name":"Husqvarna-Mower","nsid":"","expires":0,"nickname":null,"profileNum":6,"timeAdded":1649262681763,"timeStarted":null,"timeModified":1649262681763,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"d84d557c-7bed-47e5-9f2f-6c3831344545","uuid":"00:21:b9:02:38:63","token":"yVOLc60Aiwqyb1HE","name":"Push","nsid":"6f25fa27-3b43-4782-ab71-293dd3d0cac7","expires":0,"nickname":null,"profileNum":7,"timeAdded":1651780396082,"timeStarted":0,"timeModified":1660690774255,"version":"2.0.2","branch":"master","url":"https://github.com/UniversalDevicesInc-PG3/udi-push-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_7","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"push-poly.py","shortPoll":60,"longPoll":600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":"controller","status_driver":"ST","orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"1a23a3f9-dfe2-43eb-9835-3cf755c76064","uuid":"00:21:b9:02:38:63","token":"NspM+TxMZ=gKb)0c","name":"WeatherBit","nsid":"","expires":0,"nickname":null,"profileNum":8,"timeAdded":1649262681442,"timeStarted":null,"timeModified":1649262681442,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1266def9-64a6-4d65-a631-bd9abdab9aae","uuid":"00:21:b9:02:38:63","token":"sFnryBAv=n)ig0&z","name":"OpenWeatherMap","nsid":"","expires":0,"nickname":null,"profileNum":9,"timeAdded":1649262681481,"timeStarted":null,"timeModified":1649262681481,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"86e06af1-4710-47e9-bd40-ed06e5ff24a8","uuid":"00:21:b9:02:38:63","token":"w2wzHcPBx9QM643&","name":"Timedata","nsid":"","expires":0,"nickname":null,"profileNum":10,"timeAdded":1649262681699,"timeStarted":null,"timeModified":1649262681699,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1310b0c5-e41a-4474-b0b6-118a38432837","uuid":"00:21:b9:02:38:63","token":"oPO&ho1XC5=qGVW0","name":"DarkSky","nsid":"","expires":0,"nickname":null,"profileNum":11,"timeAdded":1649262681520,"timeStarted":null,"timeModified":1649262681520,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"72d96b7c-3cea-420d-9f2b-8596c4046aab","uuid":"00:21:b9:02:38:63","token":"mg9HwtQiyMhGvo4-","name":"PythonTemplate","nsid":"","expires":0,"nickname":null,"profileNum":12,"timeAdded":1649262681589,"timeStarted":null,"timeModified":1649262681589,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"7167da51-66dc-4164-9195-670ac0bd7147","uuid":"00:21:b9:02:38:63","token":"O5xHB/4UAm1-o5lr","name":"ISY-Inventory","nsid":"","expires":0,"nickname":null,"profileNum":13,"timeAdded":1649262681613,"timeStarted":null,"timeModified":1649262681613,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"30901362-b48c-4f80-87c7-c60cf390a100","uuid":"00:21:b9:02:38:63","token":"aq*iCFnhp&(59lh)","name":"Virtual","nsid":"","expires":0,"nickname":null,"profileNum":14,"timeAdded":1649262681641,"timeStarted":null,"timeModified":1649262681641,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"907b144c-00b9-435c-859d-40f9425e610d","uuid":"00:21:b9:02:38:63","token":"x5u8PamwV7eLnU4l","name":"Backup","nsid":"eeecfdd1-65df-4ebd-aeec-8bb9613fb77d","expires":0,"nickname":null,"profileNum":15,"timeAdded":1651530412554,"timeStarted":1660690762709,"timeModified":1660690773872,"version":"2.0.4","branch":"master","url":"https://github.com/BME-node servers/udi-backup-poly.git","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_15","log":"logs/debug.log","logLevel":"ERROR","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"backup.py","shortPoll":5,"longPoll":60,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"2113cdbd-f9a0-4304-ab43-c6f4c47d3308","uuid":"00:21:b9:02:38:63","token":"3))1%o?WSwSpaM3?","name":"ELK","nsid":"","expires":0,"nickname":null,"profileNum":16,"timeAdded":1649262681565,"timeStarted":null,"timeModified":1649262681565,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"8f642351-0a8c-4f87-a039-12d1ab6053fe","uuid":"00:21:b9:02:38:63","token":"0tA%WNT-s+uNmknv","name":"UnifiPresence","nsid":"","expires":0,"nickname":null,"profileNum":17,"timeAdded":1649262681721,"timeStarted":null,"timeModified":1649262681721,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"ecc02620-c469-417a-82ca-ddd9e933eddc","uuid":"00:21:b9:02:38:63","token":"R62=Sx*6IgiceO+k","name":"FlumeWater","nsid":"","expires":0,"nickname":null,"profileNum":18,"timeAdded":1649262681742,"timeStarted":null,"timeModified":1649262681742,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"55bc2641-0657-45b2-b265-7f5e36544491","uuid":"00:21:b9:02:38:63","token":"XJq!TKZfLCFlJMa1","name":"SenseMonitoring","nsid":"","expires":0,"nickname":null,"profileNum":19,"timeAdded":1649262681324,"timeStarted":null,"timeModified":1649262681324,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"39f5bcb7-2f09-4f38-ab06-e83e27a1b163","uuid":"00:21:b9:02:38:63","token":"sUrTe0EgxVUL!T?n","name":"iTach-IR","nsid":"60f7f035-0f0b-4a7c-8b65-457525b90a50","expires":0,"nickname":null,"profileNum":20,"timeAdded":1651127099212,"timeStarted":1660690762519,"timeModified":1660690775051,"version":"2022.08.01","branch":"main","url":"https://github.com/JavierRefuerzo/iTach_IR_Node_Server.git","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_20","log":"logs/debug.log","logLevel":"WARNING","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"initializer.py","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":2,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"52f7d636-ed56-4567-9786-d5779c0e727b","uuid":"00:21:b9:02:38:63","token":"2bzpMQQQGkzca3x=","name":"Roomba","nsid":"3e24cce1-59d3-45b3-9bde-7adedd954d38","expires":0,"nickname":null,"profileNum":21,"timeAdded":1651191536730,"timeStarted":0,"timeModified":1660690845774,"version":"2.0.7","branch":"master","url":"https://github.com/BME-node servers/udi-roomba-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_21","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"roomba-poly.py","shortPoll":5,"longPoll":60,"nsInfoPoll":0,"discover":1,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{}},{"id":"a7f01228-e409-4dbb-aba4-f94d536b7b52","uuid":"00:21:b9:02:38:63","token":"wV1f(6u3DkM&&nUK","name":"TeslaEV","nsid":"1d0462a1-2e9a-4b15-9a8a-ed70d641cc72","expires":0,"nickname":null,"profileNum":22,"timeAdded":1656164106820,"timeStarted":0,"timeModified":1660691565756,"version":"0.1.19","branch":"main","url":"https://github.com/Panda88CO/udi-TeslaEV","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_22","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"TeslaEVController.py","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{}},{"id":"50a94be1-8d93-47ef-a899-053cf584b152","uuid":"00:21:b9:02:38:63","token":"8cI*1KLZJG)Uc%4x","name":"Tesla","nsid":"","expires":0,"nickname":null,"profileNum":23,"timeAdded":1660656534880,"timeStarted":null,"timeModified":1660656534880,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0}]}
8/16/2022, 18:17:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76 to broker pg3_broker
8/16/2022, 18:17:36 [pg3] debug: MQTT Results: [frontend/system/admin] :: {"getIsys":[{"id":"6d87716a-83b8-4919-b568-9ed242585231","uuid":"00:21:b9:02:38:63","name":"IoP","ip":"192.168.1.9","port":8080,"username":"admin","enabled":1,"discovered":1,"version":"5.3.3","secure":0,"timeAdded":1649187118481,"timeModified":1651196030503,"dbVersion":1}],"getSettings":{"id":"ae2838f3-88fe-452c-80b9-cf00bf13fa76","name":"pg3","pg3Version":"3.0.62","mqttHost":"localhost","mqttPort":1888,"ipAddress":"192.168.1.9","bindIpAddress":"0.0.0.0","listenPort":3000,"macAddress":"00:0d:b9:52:bf:4c","secure":1,"store":"https://pg3store.isy.io/","customCerts":0,"beta":0,"timeStarted":1660690753241,"secret":null,"polisy":1,"localStore":0,"timeAdded":1649187117943,"timeModified":1660690754521,"dbVersion":1}}
8/16/2022, 18:17:36 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:17:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:17:40 [pg3] debug: Sending logfile to frontend :: /var/polyglot/pg3/logs/pg3-current.log
8/16/2022, 18:17:40 [pg3] info: MQTTS: Client Connected: pg3frontend_9Hz8C
8/16/2022, 18:17:40 [pg3] debug: Client pg3frontend_9Hz8C subscribed to udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76
8/16/2022, 18:17:40 [pg3] debug: Client pg3frontend_9Hz8C subscribed to sconfig/#
8/16/2022, 18:17:40 [pg3] debug: Client pg3frontend_9Hz8C subscribed to spolisy/#
8/16/2022, 18:17:40 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_9Hz8C has published message on udi/pg3/frontend/system/admin to broker pg3_broker
8/16/2022, 18:17:40 [pg3] debug: MQTT Results: [frontend/system/admin] :: {"getIsys":[{"id":"6d87716a-83b8-4919-b568-9ed242585231","uuid":"00:21:b9:02:38:63","name":"IoP","ip":"192.168.1.9","port":8080,"username":"admin","enabled":1,"discovered":1,"version":"5.3.3","secure":0,"timeAdded":1649187118481,"timeModified":1651196030503,"dbVersion":1}],"getSettings":{"id":"ae2838f3-88fe-452c-80b9-cf00bf13fa76","name":"pg3","pg3Version":"3.0.62","mqttHost":"localhost","mqttPort":1888,"ipAddress":"192.168.1.9","bindIpAddress":"0.0.0.0","listenPort":3000,"macAddress":"00:0d:b9:52:bf:4c","secure":1,"store":"https://pg3store.isy.io/","customCerts":0,"beta":0,"timeStarted":1660690753241,"secret":null,"polisy":1,"localStore":0,"timeAdded":1649187117943,"timeModified":1660690754521,"dbVersion":1}}
8/16/2022, 18:17:40 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76 to broker pg3_broker
8/16/2022, 18:17:40 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_9Hz8C has published message on udi/pg3/frontend/isy/admin to broker pg3_broker
8/16/2022, 18:17:40 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"425f2619-2764-4471-8f6d-1d739c4d6ec7","uuid":"00:21:b9:02:38:63","token":"!*!-rTR*Rlm%A*DB","name":"isylink","nsid":"","expires":0,"nickname":null,"profileNum":1,"timeAdded":1649262681253,"timeStarted":null,"timeModified":1649262681254,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"ec934f8e-544d-471f-8d88-fda857ece038","uuid":"00:21:b9:02:38:63","token":"XHiyu*EgnWke-MWV","name":"2","nsid":"","expires":0,"nickname":null,"profileNum":2,"timeAdded":1649262681278,"timeStarted":null,"timeModified":1649262681278,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"af39d9b8-cd5a-4f5c-b605-e905eaa7697f","uuid":"00:21:b9:02:38:63","token":"nH)O-rOue=5tfrw)","name":"ISY Portal","nsid":"","expires":0,"nickname":null,"profileNum":3,"timeAdded":1649262681301,"timeStarted":null,"timeModified":1649262681301,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"f6e82cc1-ec9c-4b36-83ec-da08eeb226d8","uuid":"00:21:b9:02:38:63","token":"vrcnCQX5GxTOlZ-x","name":"BlueIris","nsid":"bffcf8d8-f0e7-4e64-a662-1ca53314525a","expires":0,"nickname":null,"profileNum":4,"timeAdded":1651780396101,"timeStarted":0,"timeModified":1660690909055,"version":"2.0.2","branch":"master","url":"https://github.com/UniversalDevicesInc-PG3/udi-blue-iris-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_4","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"blue-iris-poly.py","shortPoll":2,"longPoll":60,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":"controller","status_driver":"ST","orderId":null,"store":"Production","dbVersion":1,"nodeCount":18,"notices":{}},{"id":"efc170e6-ef7b-4ae7-8535-0b550bc1497b","uuid":"00:21:b9:02:38:63","token":"Hp0b)Tb/b)bHAvBn","name":"HarmonyHub","nsid":"","expires":0,"nickname":null,"profileNum":5,"timeAdded":1649262681408,"timeStarted":null,"timeModified":1649262681408,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"5e7fdc5d-a13b-4262-9dda-85820d4ff9ca","uuid":"00:21:b9:02:38:63","token":"%*zcuq%ccBKIeE4a","name":"Husqvarna-Mower","nsid":"","expires":0,"nickname":null,"profileNum":6,"timeAdded":1649262681763,"timeStarted":null,"timeModified":1649262681763,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"d84d557c-7bed-47e5-9f2f-6c3831344545","uuid":"00:21:b9:02:38:63","token":"yVOLc60Aiwqyb1HE","name":"Push","nsid":"6f25fa27-3b43-4782-ab71-293dd3d0cac7","expires":0,"nickname":null,"profileNum":7,"timeAdded":1651780396082,"timeStarted":0,"timeModified":1660690774255,"version":"2.0.2","branch":"master","url":"https://github.com/UniversalDevicesInc-PG3/udi-push-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_7","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"push-poly.py","shortPoll":60,"longPoll":600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":"controller","status_driver":"ST","orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"1a23a3f9-dfe2-43eb-9835-3cf755c76064","uuid":"00:21:b9:02:38:63","token":"NspM+TxMZ=gKb)0c","name":"WeatherBit","nsid":"","expires":0,"nickname":null,"profileNum":8,"timeAdded":1649262681442,"timeStarted":null,"timeModified":1649262681442,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1266def9-64a6-4d65-a631-bd9abdab9aae","uuid":"00:21:b9:02:38:63","token":"sFnryBAv=n)ig0&z","name":"OpenWeatherMap","nsid":"","expires":0,"nickname":null,"profileNum":9,"timeAdded":1649262681481,"timeStarted":null,"timeModified":1649262681481,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"86e06af1-4710-47e9-bd40-ed06e5ff24a8","uuid":"00:21:b9:02:38:63","token":"w2wzHcPBx9QM643&","name":"Timedata","nsid":"","expires":0,"nickname":null,"profileNum":10,"timeAdded":1649262681699,"timeStarted":null,"timeModified":1649262681699,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1310b0c5-e41a-4474-b0b6-118a38432837","uuid":"00:21:b9:02:38:63","token":"oPO&ho1XC5=qGVW0","name":"DarkSky","nsid":"","expires":0,"nickname":null,"profileNum":11,"timeAdded":1649262681520,"timeStarted":null,"timeModified":1649262681520,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"72d96b7c-3cea-420d-9f2b-8596c4046aab","uuid":"00:21:b9:02:38:63","token":"mg9HwtQiyMhGvo4-","name":"PythonTemplate","nsid":"","expires":0,"nickname":null,"profileNum":12,"timeAdded":1649262681589,"timeStarted":null,"timeModified":1649262681589,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"7167da51-66dc-4164-9195-670ac0bd7147","uuid":"00:21:b9:02:38:63","token":"O5xHB/4UAm1-o5lr","name":"ISY-Inventory","nsid":"","expires":0,"nickname":null,"profileNum":13,"timeAdded":1649262681613,"timeStarted":null,"timeModified":1649262681613,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"30901362-b48c-4f80-87c7-c60cf390a100","uuid":"00:21:b9:02:38:63","token":"aq*iCFnhp&(59lh)","name":"Virtual","nsid":"","expires":0,"nickname":null,"profileNum":14,"timeAdded":1649262681641,"timeStarted":null,"timeModified":1649262681641,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"907b144c-00b9-435c-859d-40f9425e610d","uuid":"00:21:b9:02:38:63","token":"x5u8PamwV7eLnU4l","name":"Backup","nsid":"eeecfdd1-65df-4ebd-aeec-8bb9613fb77d","expires":0,"nickname":null,"profileNum":15,"timeAdded":1651530412554,"timeStarted":1660690762709,"timeModified":1660690773872,"version":"2.0.4","branch":"master","url":"https://github.com/BME-node servers/udi-backup-poly.git","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_15","log":"logs/debug.log","logLevel":"ERROR","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"backup.py","shortPoll":5,"longPoll":60,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"2113cdbd-f9a0-4304-ab43-c6f4c47d3308","uuid":"00:21:b9:02:38:63","token":"3))1%o?WSwSpaM3?","name":"ELK","nsid":"","expires":0,"nickname":null,"profileNum":16,"timeAdded":1649262681565,"timeStarted":null,"timeModified":1649262681565,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"8f642351-0a8c-4f87-a039-12d1ab6053fe","uuid":"00:21:b9:02:38:63","token":"0tA%WNT-s+uNmknv","name":"UnifiPresence","nsid":"","expires":0,"nickname":null,"profileNum":17,"timeAdded":1649262681721,"timeStarted":null,"timeModified":1649262681721,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"ecc02620-c469-417a-82ca-ddd9e933eddc","uuid":"00:21:b9:02:38:63","token":"R62=Sx*6IgiceO+k","name":"FlumeWater","nsid":"","expires":0,"nickname":null,"profileNum":18,"timeAdded":1649262681742,"timeStarted":null,"timeModified":1649262681742,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"55bc2641-0657-45b2-b265-7f5e36544491","uuid":"00:21:b9:02:38:63","token":"XJq!TKZfLCFlJMa1","name":"SenseMonitoring","nsid":"","expires":0,"nickname":null,"profileNum":19,"timeAdded":1649262681324,"timeStarted":null,"timeModified":1649262681324,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"39f5bcb7-2f09-4f38-ab06-e83e27a1b163","uuid":"00:21:b9:02:38:63","token":"sUrTe0EgxVUL!T?n","name":"iTach-IR","nsid":"60f7f035-0f0b-4a7c-8b65-457525b90a50","expires":0,"nickname":null,"profileNum":20,"timeAdded":1651127099212,"timeStarted":1660690762519,"timeModified":1660690775051,"version":"2022.08.01","branch":"main","url":"https://github.com/JavierRefuerzo/iTach_IR_Node_Server.git","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_20","log":"logs/debug.log","logLevel":"WARNING","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"initializer.py","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":2,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"52f7d636-ed56-4567-9786-d5779c0e727b","uuid":"00:21:b9:02:38:63","token":"2bzpMQQQGkzca3x=","name":"Roomba","nsid":"3e24cce1-59d3-45b3-9bde-7adedd954d38","expires":0,"nickname":null,"profileNum":21,"timeAdded":1651191536730,"timeStarted":0,"timeModified":1660690845774,"version":"2.0.7","branch":"master","url":"https://github.com/BME-node servers/udi-roomba-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_21","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"roomba-poly.py","shortPoll":5,"longPoll":60,"nsInfoPoll":0,"discover":1,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{}},{"id":"a7f01228-e409-4dbb-aba4-f94d536b7b52","uuid":"00:21:b9:02:38:63","token":"wV1f(6u3DkM&&nUK","name":"TeslaEV","nsid":"1d0462a1-2e9a-4b15-9a8a-ed70d641cc72","expires":0,"nickname":null,"profileNum":22,"timeAdded":1656164106820,"timeStarted":0,"timeModified":1660691565756,"version":"0.1.19","branch":"main","url":"https://github.com/Panda88CO/udi-TeslaEV","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_22","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"TeslaEVController.py","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{}},{"id":"50a94be1-8d93-47ef-a899-053cf584b152","uuid":"00:21:b9:02:38:63","token":"8cI*1KLZJG)Uc%4x","name":"Tesla","nsid":"","expires":0,"nickname":null,"profileNum":23,"timeAdded":1660656534880,"timeStarted":null,"timeModified":1660656534880,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0}]}
8/16/2022, 18:17:40 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_x16kS has published message on udi/pg3/frontend/isy/admin to broker pg3_broker
8/16/2022, 18:17:41 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:17:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:17:46 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:17:46 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:17:51 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:17:51 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:17:55 [pg3] warn: MQTTS: keepaliveTimeout: pg3frontend_9Hz8C
8/16/2022, 18:17:55 [pg3] error: MQTTS: clientError: pg3frontend_9Hz8C keep alive timeout
8/16/2022, 18:17:55 [pg3] info: MQTTS: Client Disconnected: pg3frontend_9Hz8C
8/16/2022, 18:17:55 [pg3] debug: Client pg3frontend_9Hz8C unsubscribed from udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76
8/16/2022, 18:17:55 [pg3] debug: Client pg3frontend_9Hz8C unsubscribed from sconfig/#
8/16/2022, 18:17:55 [pg3] debug: Client pg3frontend_9Hz8C unsubscribed from spolisy/#
8/16/2022, 18:17:56 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:17:56 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:01 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:01 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:06 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:06 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:11 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:11 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:16 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:16 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:21 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:21 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:25 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_20] {"shortPoll":{}}
8/16/2022, 18:18:25 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"longPoll":{}}
8/16/2022, 18:18:25 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_20 to broker pg3_broker
8/16/2022, 18:18:25 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:26 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:26 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:31 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:31 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:36 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:36 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:39 [pg3] warn: MQTTS: keepaliveTimeout: pg3frontend_x16kS
8/16/2022, 18:18:39 [pg3] error: MQTTS: clientError: pg3frontend_x16kS keep alive timeout
8/16/2022, 18:18:39 [pg3] info: MQTTS: Client Disconnected: pg3frontend_x16kS
8/16/2022, 18:18:39 [pg3] debug: Client pg3frontend_x16kS unsubscribed from udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76
8/16/2022, 18:18:39 [pg3] debug: Client pg3frontend_x16kS unsubscribed from sconfig/#
8/16/2022, 18:18:39 [pg3] debug: Client pg3frontend_x16kS unsubscribed from spolisy/#
8/16/2022, 18:18:41 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:41 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:44 [pg3] info: MQTTS: Client Connected: pg3frontend_9Hz8C
8/16/2022, 18:18:44 [pg3] debug: Client pg3frontend_9Hz8C subscribed to udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76
8/16/2022, 18:18:44 [pg3] debug: Client pg3frontend_9Hz8C subscribed to sconfig/#
8/16/2022, 18:18:44 [pg3] debug: Client pg3frontend_9Hz8C subscribed to spolisy/#
8/16/2022, 18:18:44 [pg3] debug: Client pg3frontend_9Hz8C subscribed to udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76/log/main
8/16/2022, 18:18:44 [pg3] debug: Starting log stream for pg3frontend_9Hz8C :: /var/polyglot/pg3/logs/pg3-current.log
8/16/2022, 18:18:44 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_9Hz8C has published message on udi/pg3/frontend/isy/admin to broker pg3_broker
8/16/2022, 18:18:44 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_9Hz8C has published message on udi/pg3/frontend/system/admin to broker pg3_broker
8/16/2022, 18:18:44 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"425f2619-2764-4471-8f6d-1d739c4d6ec7","uuid":"00:21:b9:02:38:63","token":"!*!-rTR*Rlm%A*DB","name":"isylink","nsid":"","expires":0,"nickname":null,"profileNum":1,"timeAdded":1649262681253,"timeStarted":null,"timeModified":1649262681254,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"ec934f8e-544d-471f-8d88-fda857ece038","uuid":"00:21:b9:02:38:63","token":"XHiyu*EgnWke-MWV","name":"2","nsid":"","expires":0,"nickname":null,"profileNum":2,"timeAdded":1649262681278,"timeStarted":null,"timeModified":1649262681278,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"af39d9b8-cd5a-4f5c-b605-e905eaa7697f","uuid":"00:21:b9:02:38:63","token":"nH)O-rOue=5tfrw)","name":"ISY Portal","nsid":"","expires":0,"nickname":null,"profileNum":3,"timeAdded":1649262681301,"timeStarted":null,"timeModified":1649262681301,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"f6e82cc1-ec9c-4b36-83ec-da08eeb226d8","uuid":"00:21:b9:02:38:63","token":"vrcnCQX5GxTOlZ-x","name":"BlueIris","nsid":"bffcf8d8-f0e7-4e64-a662-1ca53314525a","expires":0,"nickname":null,"profileNum":4,"timeAdded":1651780396101,"timeStarted":0,"timeModified":1660690909055,"version":"2.0.2","branch":"master","url":"https://github.com/UniversalDevicesInc-PG3/udi-blue-iris-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_4","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"blue-iris-poly.py","shortPoll":2,"longPoll":60,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":"controller","status_driver":"ST","orderId":null,"store":"Production","dbVersion":1,"nodeCount":18,"notices":{}},{"id":"efc170e6-ef7b-4ae7-8535-0b550bc1497b","uuid":"00:21:b9:02:38:63","token":"Hp0b)Tb/b)bHAvBn","name":"HarmonyHub","nsid":"","expires":0,"nickname":null,"profileNum":5,"timeAdded":1649262681408,"timeStarted":null,"timeModified":1649262681408,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"5e7fdc5d-a13b-4262-9dda-85820d4ff9ca","uuid":"00:21:b9:02:38:63","token":"%*zcuq%ccBKIeE4a","name":"Husqvarna-Mower","nsid":"","expires":0,"nickname":null,"profileNum":6,"timeAdded":1649262681763,"timeStarted":null,"timeModified":1649262681763,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"d84d557c-7bed-47e5-9f2f-6c3831344545","uuid":"00:21:b9:02:38:63","token":"yVOLc60Aiwqyb1HE","name":"Push","nsid":"6f25fa27-3b43-4782-ab71-293dd3d0cac7","expires":0,"nickname":null,"profileNum":7,"timeAdded":1651780396082,"timeStarted":0,"timeModified":1660690774255,"version":"2.0.2","branch":"master","url":"https://github.com/UniversalDevicesInc-PG3/udi-push-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_7","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"push-poly.py","shortPoll":60,"longPoll":600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":"controller","status_driver":"ST","orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"1a23a3f9-dfe2-43eb-9835-3cf755c76064","uuid":"00:21:b9:02:38:63","token":"NspM+TxMZ=gKb)0c","name":"WeatherBit","nsid":"","expires":0,"nickname":null,"profileNum":8,"timeAdded":1649262681442,"timeStarted":null,"timeModified":1649262681442,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1266def9-64a6-4d65-a631-bd9abdab9aae","uuid":"00:21:b9:02:38:63","token":"sFnryBAv=n)ig0&z","name":"OpenWeatherMap","nsid":"","expires":0,"nickname":null,"profileNum":9,"timeAdded":1649262681481,"timeStarted":null,"timeModified":1649262681481,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"86e06af1-4710-47e9-bd40-ed06e5ff24a8","uuid":"00:21:b9:02:38:63","token":"w2wzHcPBx9QM643&","name":"Timedata","nsid":"","expires":0,"nickname":null,"profileNum":10,"timeAdded":1649262681699,"timeStarted":null,"timeModified":1649262681699,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1310b0c5-e41a-4474-b0b6-118a38432837","uuid":"00:21:b9:02:38:63","token":"oPO&ho1XC5=qGVW0","name":"DarkSky","nsid":"","expires":0,"nickname":null,"profileNum":11,"timeAdded":1649262681520,"timeStarted":null,"timeModified":1649262681520,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"72d96b7c-3cea-420d-9f2b-8596c4046aab","uuid":"00:21:b9:02:38:63","token":"mg9HwtQiyMhGvo4-","name":"PythonTemplate","nsid":"","expires":0,"nickname":null,"profileNum":12,"timeAdded":1649262681589,"timeStarted":null,"timeModified":1649262681589,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"7167da51-66dc-4164-9195-670ac0bd7147","uuid":"00:21:b9:02:38:63","token":"O5xHB/4UAm1-o5lr","name":"ISY-Inventory","nsid":"","expires":0,"nickname":null,"profileNum":13,"timeAdded":1649262681613,"timeStarted":null,"timeModified":1649262681613,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"30901362-b48c-4f80-87c7-c60cf390a100","uuid":"00:21:b9:02:38:63","token":"aq*iCFnhp&(59lh)","name":"Virtual","nsid":"","expires":0,"nickname":null,"profileNum":14,"timeAdded":1649262681641,"timeStarted":null,"timeModified":1649262681641,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"907b144c-00b9-435c-859d-40f9425e610d","uuid":"00:21:b9:02:38:63","token":"x5u8PamwV7eLnU4l","name":"Backup","nsid":"eeecfdd1-65df-4ebd-aeec-8bb9613fb77d","expires":0,"nickname":null,"profileNum":15,"timeAdded":1651530412554,"timeStarted":1660690762709,"timeModified":1660690773872,"version":"2.0.4","branch":"master","url":"https://github.com/BME-node servers/udi-backup-poly.git","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_15","log":"logs/debug.log","logLevel":"ERROR","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"backup.py","shortPoll":5,"longPoll":60,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"2113cdbd-f9a0-4304-ab43-c6f4c47d3308","uuid":"00:21:b9:02:38:63","token":"3))1%o?WSwSpaM3?","name":"ELK","nsid":"","expires":0,"nickname":null,"profileNum":16,"timeAdded":1649262681565,"timeStarted":null,"timeModified":1649262681565,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"8f642351-0a8c-4f87-a039-12d1ab6053fe","uuid":"00:21:b9:02:38:63","token":"0tA%WNT-s+uNmknv","name":"UnifiPresence","nsid":"","expires":0,"nickname":null,"profileNum":17,"timeAdded":1649262681721,"timeStarted":null,"timeModified":1649262681721,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"ecc02620-c469-417a-82ca-ddd9e933eddc","uuid":"00:21:b9:02:38:63","token":"R62=Sx*6IgiceO+k","name":"FlumeWater","nsid":"","expires":0,"nickname":null,"profileNum":18,"timeAdded":1649262681742,"timeStarted":null,"timeModified":1649262681742,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"55bc2641-0657-45b2-b265-7f5e36544491","uuid":"00:21:b9:02:38:63","token":"XJq!TKZfLCFlJMa1","name":"SenseMonitoring","nsid":"","expires":0,"nickname":null,"profileNum":19,"timeAdded":1649262681324,"timeStarted":null,"timeModified":1649262681324,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"39f5bcb7-2f09-4f38-ab06-e83e27a1b163","uuid":"00:21:b9:02:38:63","token":"sUrTe0EgxVUL!T?n","name":"iTach-IR","nsid":"60f7f035-0f0b-4a7c-8b65-457525b90a50","expires":0,"nickname":null,"profileNum":20,"timeAdded":1651127099212,"timeStarted":1660690762519,"timeModified":1660690775051,"version":"2022.08.01","branch":"main","url":"https://github.com/JavierRefuerzo/iTach_IR_Node_Server.git","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_20","log":"logs/debug.log","logLevel":"WARNING","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"initializer.py","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":2,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"52f7d636-ed56-4567-9786-d5779c0e727b","uuid":"00:21:b9:02:38:63","token":"2bzpMQQQGkzca3x=","name":"Roomba","nsid":"3e24cce1-59d3-45b3-9bde-7adedd954d38","expires":0,"nickname":null,"profileNum":21,"timeAdded":1651191536730,"timeStarted":0,"timeModified":1660690845774,"version":"2.0.7","branch":"master","url":"https://github.com/BME-node servers/udi-roomba-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_21","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"roomba-poly.py","shortPoll":5,"longPoll":60,"nsInfoPoll":0,"discover":1,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{}},{"id":"a7f01228-e409-4dbb-aba4-f94d536b7b52","uuid":"00:21:b9:02:38:63","token":"wV1f(6u3DkM&&nUK","name":"TeslaEV","nsid":"1d0462a1-2e9a-4b15-9a8a-ed70d641cc72","expires":0,"nickname":null,"profileNum":22,"timeAdded":1656164106820,"timeStarted":0,"timeModified":1660691565756,"version":"0.1.19","branch":"main","url":"https://github.com/Panda88CO/udi-TeslaEV","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_22","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"TeslaEVController.py","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{}},{"id":"50a94be1-8d93-47ef-a899-053cf584b152","uuid":"00:21:b9:02:38:63","token":"8cI*1KLZJG)Uc%4x","name":"Tesla","nsid":"","expires":0,"nickname":null,"profileNum":23,"timeAdded":1660656534880,"timeStarted":null,"timeModified":1660656534880,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0}]}
8/16/2022, 18:18:44 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76 to broker pg3_broker
8/16/2022, 18:18:44 [pg3] debug: MQTT Results: [frontend/system/admin] :: {"getIsys":[{"id":"6d87716a-83b8-4919-b568-9ed242585231","uuid":"00:21:b9:02:38:63","name":"IoP","ip":"192.168.1.9","port":8080,"username":"admin","enabled":1,"discovered":1,"version":"5.3.3","secure":0,"timeAdded":1649187118481,"timeModified":1651196030503,"dbVersion":1}],"getSettings":{"id":"ae2838f3-88fe-452c-80b9-cf00bf13fa76","name":"pg3","pg3Version":"3.0.62","mqttHost":"localhost","mqttPort":1888,"ipAddress":"192.168.1.9","bindIpAddress":"0.0.0.0","listenPort":3000,"macAddress":"00:0d:b9:52:bf:4c","secure":1,"store":"https://pg3store.isy.io/","customCerts":0,"beta":0,"timeStarted":1660690753241,"secret":null,"polisy":1,"localStore":0,"timeAdded":1649187117943,"timeModified":1660690754521,"dbVersion":1}}
8/16/2022, 18:18:45 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_9Hz8C has published message on udi/pg3/frontend/isy/admin to broker pg3_broker
8/16/2022, 18:18:45 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"getNodeServers":[{"id":"425f2619-2764-4471-8f6d-1d739c4d6ec7","uuid":"00:21:b9:02:38:63","token":"!*!-rTR*Rlm%A*DB","name":"isylink","nsid":"","expires":0,"nickname":null,"profileNum":1,"timeAdded":1649262681253,"timeStarted":null,"timeModified":1649262681254,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"ec934f8e-544d-471f-8d88-fda857ece038","uuid":"00:21:b9:02:38:63","token":"XHiyu*EgnWke-MWV","name":"2","nsid":"","expires":0,"nickname":null,"profileNum":2,"timeAdded":1649262681278,"timeStarted":null,"timeModified":1649262681278,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"af39d9b8-cd5a-4f5c-b605-e905eaa7697f","uuid":"00:21:b9:02:38:63","token":"nH)O-rOue=5tfrw)","name":"ISY Portal","nsid":"","expires":0,"nickname":null,"profileNum":3,"timeAdded":1649262681301,"timeStarted":null,"timeModified":1649262681301,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"f6e82cc1-ec9c-4b36-83ec-da08eeb226d8","uuid":"00:21:b9:02:38:63","token":"vrcnCQX5GxTOlZ-x","name":"BlueIris","nsid":"bffcf8d8-f0e7-4e64-a662-1ca53314525a","expires":0,"nickname":null,"profileNum":4,"timeAdded":1651780396101,"timeStarted":0,"timeModified":1660690909055,"version":"2.0.2","branch":"master","url":"https://github.com/UniversalDevicesInc-PG3/udi-blue-iris-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_4","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"blue-iris-poly.py","shortPoll":2,"longPoll":60,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":"controller","status_driver":"ST","orderId":null,"store":"Production","dbVersion":1,"nodeCount":18,"notices":{}},{"id":"efc170e6-ef7b-4ae7-8535-0b550bc1497b","uuid":"00:21:b9:02:38:63","token":"Hp0b)Tb/b)bHAvBn","name":"HarmonyHub","nsid":"","expires":0,"nickname":null,"profileNum":5,"timeAdded":1649262681408,"timeStarted":null,"timeModified":1649262681408,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"5e7fdc5d-a13b-4262-9dda-85820d4ff9ca","uuid":"00:21:b9:02:38:63","token":"%*zcuq%ccBKIeE4a","name":"Husqvarna-Mower","nsid":"","expires":0,"nickname":null,"profileNum":6,"timeAdded":1649262681763,"timeStarted":null,"timeModified":1649262681763,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"d84d557c-7bed-47e5-9f2f-6c3831344545","uuid":"00:21:b9:02:38:63","token":"yVOLc60Aiwqyb1HE","name":"Push","nsid":"6f25fa27-3b43-4782-ab71-293dd3d0cac7","expires":0,"nickname":null,"profileNum":7,"timeAdded":1651780396082,"timeStarted":0,"timeModified":1660690774255,"version":"2.0.2","branch":"master","url":"https://github.com/UniversalDevicesInc-PG3/udi-push-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_7","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"push-poly.py","shortPoll":60,"longPoll":600,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":"controller","status_driver":"ST","orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"1a23a3f9-dfe2-43eb-9835-3cf755c76064","uuid":"00:21:b9:02:38:63","token":"NspM+TxMZ=gKb)0c","name":"WeatherBit","nsid":"","expires":0,"nickname":null,"profileNum":8,"timeAdded":1649262681442,"timeStarted":null,"timeModified":1649262681442,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1266def9-64a6-4d65-a631-bd9abdab9aae","uuid":"00:21:b9:02:38:63","token":"sFnryBAv=n)ig0&z","name":"OpenWeatherMap","nsid":"","expires":0,"nickname":null,"profileNum":9,"timeAdded":1649262681481,"timeStarted":null,"timeModified":1649262681481,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"86e06af1-4710-47e9-bd40-ed06e5ff24a8","uuid":"00:21:b9:02:38:63","token":"w2wzHcPBx9QM643&","name":"Timedata","nsid":"","expires":0,"nickname":null,"profileNum":10,"timeAdded":1649262681699,"timeStarted":null,"timeModified":1649262681699,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"1310b0c5-e41a-4474-b0b6-118a38432837","uuid":"00:21:b9:02:38:63","token":"oPO&ho1XC5=qGVW0","name":"DarkSky","nsid":"","expires":0,"nickname":null,"profileNum":11,"timeAdded":1649262681520,"timeStarted":null,"timeModified":1649262681520,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"72d96b7c-3cea-420d-9f2b-8596c4046aab","uuid":"00:21:b9:02:38:63","token":"mg9HwtQiyMhGvo4-","name":"PythonTemplate","nsid":"","expires":0,"nickname":null,"profileNum":12,"timeAdded":1649262681589,"timeStarted":null,"timeModified":1649262681589,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"7167da51-66dc-4164-9195-670ac0bd7147","uuid":"00:21:b9:02:38:63","token":"O5xHB/4UAm1-o5lr","name":"ISY-Inventory","nsid":"","expires":0,"nickname":null,"profileNum":13,"timeAdded":1649262681613,"timeStarted":null,"timeModified":1649262681613,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"30901362-b48c-4f80-87c7-c60cf390a100","uuid":"00:21:b9:02:38:63","token":"aq*iCFnhp&(59lh)","name":"Virtual","nsid":"","expires":0,"nickname":null,"profileNum":14,"timeAdded":1649262681641,"timeStarted":null,"timeModified":1649262681641,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"907b144c-00b9-435c-859d-40f9425e610d","uuid":"00:21:b9:02:38:63","token":"x5u8PamwV7eLnU4l","name":"Backup","nsid":"eeecfdd1-65df-4ebd-aeec-8bb9613fb77d","expires":0,"nickname":null,"profileNum":15,"timeAdded":1651530412554,"timeStarted":1660690762709,"timeModified":1660690773872,"version":"2.0.4","branch":"master","url":"https://github.com/BME-node servers/udi-backup-poly.git","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_15","log":"logs/debug.log","logLevel":"ERROR","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"backup.py","shortPoll":5,"longPoll":60,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"2113cdbd-f9a0-4304-ab43-c6f4c47d3308","uuid":"00:21:b9:02:38:63","token":"3))1%o?WSwSpaM3?","name":"ELK","nsid":"","expires":0,"nickname":null,"profileNum":16,"timeAdded":1649262681565,"timeStarted":null,"timeModified":1649262681565,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"8f642351-0a8c-4f87-a039-12d1ab6053fe","uuid":"00:21:b9:02:38:63","token":"0tA%WNT-s+uNmknv","name":"UnifiPresence","nsid":"","expires":0,"nickname":null,"profileNum":17,"timeAdded":1649262681721,"timeStarted":null,"timeModified":1649262681721,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"ecc02620-c469-417a-82ca-ddd9e933eddc","uuid":"00:21:b9:02:38:63","token":"R62=Sx*6IgiceO+k","name":"FlumeWater","nsid":"","expires":0,"nickname":null,"profileNum":18,"timeAdded":1649262681742,"timeStarted":null,"timeModified":1649262681742,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"55bc2641-0657-45b2-b265-7f5e36544491","uuid":"00:21:b9:02:38:63","token":"XJq!TKZfLCFlJMa1","name":"SenseMonitoring","nsid":"","expires":0,"nickname":null,"profileNum":19,"timeAdded":1649262681324,"timeStarted":null,"timeModified":1649262681324,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0},{"id":"39f5bcb7-2f09-4f38-ab06-e83e27a1b163","uuid":"00:21:b9:02:38:63","token":"sUrTe0EgxVUL!T?n","name":"iTach-IR","nsid":"60f7f035-0f0b-4a7c-8b65-457525b90a50","expires":0,"nickname":null,"profileNum":20,"timeAdded":1651127099212,"timeStarted":1660690762519,"timeModified":1660690775051,"version":"2022.08.01","branch":"main","url":"https://github.com/JavierRefuerzo/iTach_IR_Node_Server.git","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_20","log":"logs/debug.log","logLevel":"WARNING","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":1,"devMode":0,"type":"python3","executable":"initializer.py","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":2,"notices":{"__version":"A new version of this node server is available. Restart to install the latest version"}},{"id":"52f7d636-ed56-4567-9786-d5779c0e727b","uuid":"00:21:b9:02:38:63","token":"2bzpMQQQGkzca3x=","name":"Roomba","nsid":"3e24cce1-59d3-45b3-9bde-7adedd954d38","expires":0,"nickname":null,"profileNum":21,"timeAdded":1651191536730,"timeStarted":0,"timeModified":1660690845774,"version":"2.0.7","branch":"master","url":"https://github.com/BME-node servers/udi-roomba-poly","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_21","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"roomba-poly.py","shortPoll":5,"longPoll":60,"nsInfoPoll":0,"discover":1,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":1,"notices":{}},{"id":"a7f01228-e409-4dbb-aba4-f94d536b7b52","uuid":"00:21:b9:02:38:63","token":"wV1f(6u3DkM&&nUK","name":"TeslaEV","nsid":"1d0462a1-2e9a-4b15-9a8a-ed70d641cc72","expires":0,"nickname":null,"profileNum":22,"timeAdded":1656164106820,"timeStarted":0,"timeModified":1660691565756,"version":"0.1.19","branch":"main","url":"https://github.com/Panda88CO/udi-TeslaEV","home":"/var/polyglot/pg3/ns/00:21:b9:02:38:63_22","log":"logs/debug.log","logLevel":"INFO","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"python3","executable":"TeslaEVController.py","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"Production","dbVersion":1,"nodeCount":4,"notices":{}},{"id":"50a94be1-8d93-47ef-a899-053cf584b152","uuid":"00:21:b9:02:38:63","token":"8cI*1KLZJG)Uc%4x","name":"Tesla","nsid":"","expires":0,"nickname":null,"profileNum":23,"timeAdded":1660656534880,"timeStarted":null,"timeModified":1660656534880,"version":"0.0.0","branch":"master","url":"none","home":"none","log":"logs/debug.log","logLevel":"DEBUG","logLevelList":"[{\"id\":4,\"name\":\"Debug\",\"value\":\"DEBUG\",\"level\":10},{\"id\":3,\"name\":\"Info\",\"value\":\"INFO\",\"level\":20},{\"id\":2,\"name\":\"Warning\",\"value\":\"WARNING\",\"level\":30},{\"id\":1,\"name\":\"Error\",\"value\":\"ERROR\",\"level\":40},{\"id\":0,\"name\":\"Critical\",\"value\":\"CRITICAL\",\"level\":50}]","enabled":1,"connected":0,"devMode":0,"type":"unmanaged","executable":"none","shortPoll":60,"longPoll":300,"nsInfoPoll":0,"discover":0,"oauth":0,"status_node":null,"status_driver":null,"orderId":null,"store":"","dbVersion":1,"nodeCount":0}]}
8/16/2022, 18:18:45 [pg3] info: MQTTS: Client Connected: pg3frontend_x16kS
8/16/2022, 18:18:45 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76 to broker pg3_broker
8/16/2022, 18:18:45 [pg3] debug: Client pg3frontend_x16kS subscribed to udi/pg3/frontend/clients/ae2838f3-88fe-452c-80b9-cf00bf13fa76
8/16/2022, 18:18:45 [pg3] debug: Client pg3frontend_x16kS subscribed to sconfig/#
8/16/2022, 18:18:45 [pg3] debug: Client pg3frontend_x16kS subscribed to spolisy/#
8/16/2022, 18:18:45 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_x16kS has published message on udi/pg3/frontend/isy/admin to broker pg3_broker
8/16/2022, 18:18:45 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3frontend_x16kS has published message on udi/pg3/frontend/system/admin to broker pg3_broker
8/16/2022, 18:18:45 [pg3] debug: MQTT Results: [frontend/system/admin] :: {"getIsys":[{"id":"6d87716a-83b8-4919-b568-9ed242585231","uuid":"00:21:b9:02:38:63","name":"IoP","ip":"192.168.1.9","port":8080,"username":"admin","enabled":1,"discovered":1,"version":"5.3.3","secure":0,"timeAdded":1649187118481,"timeModified":1651196030503,"dbVersion":1}],"getSettings":{"id":"ae2838f3-88fe-452c-80b9-cf00bf13fa76","name":"pg3","pg3Version":"3.0.62","mqttHost":"localhost","mqttPort":1888,"ipAddress":"192.168.1.9","bindIpAddress":"0.0.0.0","listenPort":3000,"macAddress":"00:0d:b9:52:bf:4c","secure":1,"store":"https://pg3store.isy.io/","customCerts":0,"beta":0,"timeStarted":1660690753241,"secret":null,"polisy":1,"localStore":0,"timeAdded":1649187117943,"timeModified":1660690754521,"dbVersion":1}}
8/16/2022, 18:18:46 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:46 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:51 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:51 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:56 [pg3] debug: [PUBLISH: udi/pg3/ns/clients/00:21:b9:02:38:63_15] {"shortPoll":{}}
8/16/2022, 18:18:56 [pg3] debug: [MESSAGE_PUBLISHED] Client pg3_client has published message on udi/pg3/ns/clients/00:21:b9:02:38:63_15 to broker pg3_broker
8/16/2022, 18:18:58 [pg3] debug: Downloading logfile :: /var/polyglot/pg3/logs/pg3-current.log
      37.8k
      377.5k
