Russound NS - MCA series?
GQuack
Go to solution Solved by bpwwer,
Hey Bob, the documentation on your Russound NS specifies CAV/CVS receivers. Do you know if this will work as well for the MCA series before I spend my $25?
@GQuack
The russound MCA types require the RussoundRIO NS which isn't available on the PG3 platform at this time. I also have been waiting to move to the PG3 version from the PG2 version when it becomes available for my MCA-C5s.
It's on my list to add RIO support to the PG3 version, just need to find the time.
  • Thanks 1
On 8/31/2022 at 10:54 PM, GQuack said:
Hi @dbwarner5, pretty sure you said you have your Russound MCA-88 node server working. What node server are you running?
As mentioned above, I am using the RussoundRio on PG2. Works great.. occasionally though for some reason it will cause the MCA to lock up and I have to reboot it. Not sure why. Very infrequent, but worth mentioning.
  • 3 weeks later...
@bpwwer FYI.. happened again yesterday. Russound becomes unavailable even directly through their app. Need to unplug and reboot and all is fine.
  • 4 months later...
Posted (edited)
Hi Bob, I know you continue to be swamped with all the current release issues. Just Fyi, my russound MCA-88 continues to crash / lock up about once every 3-4 weeks. Am not sure if it's the NS or something else. I have attached my log fyi. It looks like all was fine at 3am when the system query ran, but then I have the following program that runs at 4am, and it looks like the Russound went down. Not sure which event caused it, if either.
FYI for when you get around to converting the NS from PG2 to PG3. Thanks! Doug
Rus Reset all to A - [ID 02ED][Parent 02EC]
        Time is  4:05:00AM
        Set 'RussoundRIO / Bedroom Sound' Source Source 1
        Wait  5 seconds
        Set 'RussoundRIO / Bedroom Sound' Zone Off
        Wait  5 seconds
        Set 'RussoundRIO / Deck Sound' Source Source 1
        Wait  5 seconds
        Set 'RussoundRIO / Deck Sound' Zone Off
        Wait  5 seconds
        Set 'RussoundRIO / Game Room Sound' Source Source 1
        Wait  5 seconds
        Set 'RussoundRIO / Game Room Sound' Zone Off
        Wait  5 seconds
        Set 'RussoundRIO / Garage Sound' Source Source 1
        Wait  5 seconds
        Set 'RussoundRIO / Garage Sound' Zone Off
        Wait  5 seconds
        Set 'RussoundRIO / Kitchen Sound' Source Source 1
        Wait  5 seconds
        Set 'RussoundRIO / Kitchen Sound' Zone Off
        Wait  5 seconds
        Set 'RussoundRIO / Laundry Room Sound' Source Source 1
        Wait  5 seconds
        Set 'RussoundRIO / Laundry Room Sound' Zone Off
        Wait  5 seconds
        Set 'RussoundRIO / Screened Porch Sound' Source Source 1
        Wait  5 seconds
        Set 'RussoundRIO / Screened Porch Sound' Zone Off
        Wait  5 seconds
        Set 'RussoundRIO / Sunroom Sound' Source Source 1
        Wait  5 seconds
        Set 'RussoundRIO / Sunroom Sound' Zone Off
RussoundRIO_logs_2-21-2023_105846_AM.zip
RussoundRIO_2-21-2023_114606_AM.txt
Edited by dbwarner5
  • 4 months later...
@bpwwer Hi bob, any update on your timing to complete the PGX version of the RussoundRIO NS?
Now that PG2 is gone, my house isnt the same without this interface. I do have a laborious work around using Alexa, Russound Skill and variables that can work, its not reliable and I undid it all when the PG2 NS was working.
So am trying to evaluate your time frame vs my time / effort to recreate the Alexa linkage. Would be willing to pay an initial "developers" fee to help if needed!!  cheers.
  • Like 1
I just finished up the changes to the WeatherFlow node server and I need to test and release that.  Adding RIO support to the Russound node server is what I'll work on next, but I don't really know how much effort it is to take the RIO support from the PG2 node server and incorporate it into the PG3 Russound node server so it's hard to estimate the time.  I want to say a couple of weeks, but that's not guaranteed.
  • Like 3
First test version with RIO support in the non-production (beta) store.  Version 2.0.5
This is only available as a trial since I expect it to have problems/issues as my testing is only with a simple RIO simulator.  Please test and document the issues you find.
  • Like 1
Posted (edited)
I installed the Russound NS 2.0.5 from the non production store. I selected RIO and port 9621. The 6 zones for the first controller was loaded but the second controller was not. They are  connected together with the required patch cords. This was the setup for the PG2 version.
I noticed that I was not getting any status returns such as Source number and volume db. After a few minutes I was unable to select a source. This is the log when selecting a source.
2023-08-03 20:49:23,120 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2023-08-03 20:49:23,120 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
2023-08-03 20:49:31,557 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message command
2023-08-03 20:49:31,557 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING command
2023-08-03 20:49:31,557 Command udi_interface DEBUG zone:process_cmd: ISY sent: {'address': 'zone_3', 'cmd': 'SOURCE', 'value': '2', 'uom': '25', 'query': {}}
2023-08-03 20:49:31,557 Command udi_interface DEBUG russound_main:Send: RIO: Sending b'EVENT C[1].Z[3]!KeyRelease SelectSource 2\r\n'
I included the log from startup.
Thanks Gary
New Text Document (3).txt
Edited by garybixler
Thanks @garybixler!
I'll have to look into the issue with the second controller.  This node server was designed to support multiple-controllers but it doesn't recognize that they are linked so you have to add each one individually in the config.  At least that's how it works for RNET based controllers.
I'm looking through the log now and it looks like you clicked the "Add Controller" button for a second controller, but didn't configure a second controller.  The log shows
Processing controller {'port': 5000, 'nwprotocol': 'TCP', 'protocol': 'RNET'}
Which fails.  I don't think this is causing any other issues, but you probably should fix the configuration.
The next thing I see is that your controller is reporting it's type as MCA-C5.   I don't see that listed in the Russound RIO documentation, it only mentions MCA-66, MCA-88, and MCA-C6.  The node server assumes that since it's not a MCA-88 that it's a 6 zone, 6 source controller.  Is that correct?
The problem was that the node server is waiting for the response to the get source name command but I had formatted the command wrong so it never got the source name, just an error response.  It was sitting there waiting for the first source name.  This should be fixed in 2.0.6 which is in the beta store now.
Posted (edited)
@bpwwer Hi.  I did inadvertently click the add controller button but later removed it. In the previous version of Russound RIO in PG2 the second controller was seen as one with 12 zones. Should actually be 16 zones as two on each controller are line out zones. Previously the only difference between the MCA- 88 and the MCA-C5 was that the C5 needed to be polled every so often to keep it alive.
After a restart I Just discovered that Source selection no longer appears. Just 0. Didn't see 2.0.6 yet but will give that a try when available.
Thanks Gary
When I do a Zone On on zone 3 (0ffice) I get this response.
2023-08-04 17:59:17,765 Command udi_interface.interface ERROR interface:_handleInput: _parseInput: node address zone_3 does not exist. {'address': 'zone_3', 'cmd': 'DFON', 'query': {}}
2023-08-04 17:59:17,765 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING command
2023-08-04 17:59:19,091 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
2023-08-04 17:59:19,091 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
So the MCA-C5 is a 8 zone, 8 source controller.   The RIO docs don't mention it so I wasn't sure.  Version 2.0.6 will assume it's 6 zone, 6 source controller so expect that.  I'll fix it so it's 8 zone, 8 source in the next release.
The main goal with this release is to make sure it does create the 6 zone nodes and does show the sources you have configured (at least up to 6).
Zone commands should work now too as it should no longer get stuck trying to access the source names.
If you use the 'Refresh Store' button, it should show the new version.  Otherwise you could have to wait up to 8 hours for it to show up automatically.
Got it. So far the only thing I see is that the source selections are one off. My sources (AM/FM, Cable, Computer, ECHO, etc)
When selecting Cable I get AM/FM and when selecting Computer I get Cable. When selecting AM/FM it defaults to Cable but is on AM/FM source.
Thanks Gary
The second controller isn't connected to Ethernet. Not sure how it would react seeing that the first controller is connected to Ethernet and talks to the second controller using the RNET link allowing each to control global functions like Party Mode.
Thanks Gary
I just submitted version 2.0.7.  This has support for chained controllers. It should detect you're second controller and add the sources and zones for it.
To make this work, the zone addresses changed, so you might want to delete version 2.0.6 and install 2.0.7 instead of re-installing.
It was a pretty massive change to support multiple controllers this way so hopefully I didn't break it too bad.
I think I fixed the source selection bug too.
  • Like 1
Posted (edited)
I just tried 2.0.7 but nothing is being discovered. Just shows RussoundCtl_1.  I entered the IP address, port 9621, TCP and RIO into the config. Did a Re-Discover but no nodes were found. I included the log from restart and Re-Discover. Hope it helps.
Thanks Gary
 I did delete 2.0.6 and installed 2.0.7.
Sorry, that was my fault. I last tested with RNET and missed updating one of the functions for RIO. Should be good with version 2.0.8 which I just submitted.
  • Like 1
  • Thanks 1
WOW everything looks great.  I just need to check if the C3, C5 series needs to be polled in order to keep the connection alive so that status info is received. If needed I have been using this program. I think it will take about an hour to find out. If needed maybe there would be a cleaner way of doing it within the NS. But many thanks for all you work.
Thanks Gary
Russound Keep Alive - [ID 0095][Parent 0054][Not Enabled]
        Repeat Every  20 minutes
           Set 'RussoundCtl_1 / Bedroom 1' Treble -1
           Wait  10 seconds
           Set 'RussoundCtl_1 / Bedroom 1' Treble 0
      37.8k
      377.9k
