How to find what programs a device belongs to?
Solved by larryllix
29 minutes ago, Blackbird said:
Is it possible to find out all (and which)the programs a device is in?
Yup. Right click on any program name in the program tree and select Search, Programs, pick one. Keep clicking it repeatedly until you don;t see any update onscreen, and then it will be looping back to the beginning again.
ooops! Select Device, not program.
@larryllix
Could you post a screenshot of your "search" option. Are you referring to "find/replace"?
Yes. I guess the label was different.
@larryllixThe other day I right clicked on a device on the main tab, by accident and I saw "find/replace".  I figured I would come back to it later and check it out.  Well, It is not there anymore.  I can't find "find/replace" anywhere.  Does the device have to be in a failed state?
@CPrince as mentioned Find/Replace is only on the Program tree.  On the Device tree, click whatever the top node is to get the "summary" page.   Then click column headings to resort by one column or another, or reverse the current column.
