Cannot control Hue after power outage
Lore
I'm having what seems to be the same issue.  I was using the original hardware ISY and the Hue V2 node, then I recently upgraded to Polisy ISY and the Hue V3 node.  Same before and after the upgrades.  The Hue lights can't be controlled by the ISY after a power failure.  I can mess with it and get it working again, usually by restarting the V3 Hue node and pulling down the nodes on the ISY.
Do you have the Hue Hub with an IP reservation in your router?
Take a look at this thread for setting up bridge/hub IP address:
If this doesn’t help look at the log for the Hue node server and post any errors you might have.
  • 3 weeks later...
I have IP reservations for everything, the HUE hub and the Polisy.  They're replacing the electrical wires and transformers in my area so I've been suffering a lot of scheduled power outages.  I was hoping, after moving to ISY on Polisy HUE would magically work after an outage, but alas, it did not.  After a power outage the HUE node is empty so I have to restart it, then I have to scan for nodes on the ISY and my HUE scripts works again.  I also have a few Insteon low voltage moduals that are reversed states that must be cycled to get into the right state, making it more work than it should be to fully recover from an outage.  For now, I threw on a huge UPS and haven't had time to more completely debug what happens after the power is restored.
      37.8k
      377.9k
