andrew77 Posted October 30, 2022 Posted October 30, 2022 Hi guys, I have Alexa able to trigger my projector, apple tv, etc with a voice command. Its worked fine until yesterday. Now when I give the voice command she says "Oaky" as usual but only sets the lights. The hub has the green light on the front so I assume(?) it's working fine. I also have everything hooked up to an IR system and when I use the voice command I don't see any of the IR blasters flash red (sending on and off signals) I've disabled and enabled the Harmony Skill. I can turn on the gear with the Harmony remote but not with the voice control. Any help would be great. Drew
lilyoyo1 Posted October 31, 2022 Posted October 31, 2022 5 hours ago, andrew77 said: Hi guys, I have Alexa able to trigger my projector, apple tv, etc with a voice command. Its worked fine until yesterday. Now when I give the voice command she says "Oaky" as usual but only sets the lights. The hub has the green light on the front so I assume(?) it's working fine. I also have everything hooked up to an IR system and when I use the voice command I don't see any of the IR blasters flash red (sending on and off signals) I've disabled and enabled the Harmony Skill. I can turn on the gear with the Harmony remote but not with the voice control. Any help would be great. Drew Sounds like an Amazon/harmony issue. You may want to check on their forums. 1
andrew77 Posted October 31, 2022 Author Posted October 31, 2022 13 hours ago, lilyoyo1 said: Sounds like an Amazon/harmony issue. You may want to check on their forums. I posted my question there. Thanks for the tip. They aren't as active or as helpful on that forum I find but it does sound like an Alexa/Amazon issue
