Name ISY994 in ISY (IoX) Finder
YEARS ago, I set up two ISY994i's in two different locations and was able to somewhere name each of them. As an example I renamed one from simply "ISY" to Tucson-ISY and that shows up in the ISY-FInder.
Where is this set today? It is on a static IP, not DHCP so nothing assigned there or in my router or HOSTS file.
Thanks for any insight! It helps to know which is which easily when using a VPN.
John
Solved by Geddy
@johnjces I believe if you're in the admin console and you rename the ISY in the tree it will then push that name to the Finder.
Just right click on the ISY name and "Rename" is an option. Close admin console and re-launch IoX (ISY) Launcher and it should display the new name.
Geddy,
Thank-you! There bigger than life! I was looking too deep.
John
