Want to key other new Schlage locks like my BE469ZP
granitehead
I will be purchasing several other keyed Schlage levers / deadbolts and I want them all to work with my BE469ZP key. Build.com lets you key in a "key code". What is the key code for the BE469ZP? Is it the 6-digit Programming Code? Or the 5-digit "DSK" code? Both of which are on the back of the guide that came with the smart deadbolt. Or something else?
@granitehead if you're speaking of a key code for physical keys, its a 5 digit code stamped on OEM keys or provided by a locksmith if locks have been re-keyed.
The number specifically indicated the depth of cut for each of the 5 pins in the cylinder.  (A 6-pin lock will have a 6 digit code.  Residential locks tend to be 5-pin and commercial locks tend to be 6-pin, but that rule isn't hard and fast.)   That said I have no idea what manual cylinder is in a BE469ZP.
It would be the number stamped on back of an original key. Not sure if it is stamped any where else.
