Why is my ISY trying to talk to my Polisy
Good morning, I currently run my ISY in parallel with my Polisy, mostly because I need Polisy/zwave functionality for a zwave switch in my shop.
I thought I'd check the logs in my ISY this morning and I'm seeing hundreds of these auth errors in my ISY Error Log.
The address 192.168.0.123 is my Polisy.
Sat 2022/11/19 08:50:33 AM    System    -170001    [Auth:-10103] 192.168.0.123:49453->80, Num=3
Sat 2022/11/19 08:50:33 AM    System    -170001    [Auth:-10103] 192.168.0.123:49453->80, Num=4
Is there any reason the ISY would repeated try to authorize itself to the ISY?
Maybe it's early but it's not obvious to me why this is happening...
Solved by MrBill
Are you running any node servers on Polisy?  The ISY's credentials should be stored in the PG2 and PG3 menu, so that Polisy can log into the ISY as a user.
In PG2, Settings > Polyglot settings.  Should have the stored credentials of the ISY.
In PG3, it's in the "ISY's" menu, edit current ISY,  and the store the cedentials to the ISY there.
Thanks @MrBillthat was it, for some unknown reason I had Polglot v3 pointing to the ISY with bad credentials.  Of course that generated an error in the log. (should have thought of that)
I don't run nodes on v3 yet.
All good now.
Edited by mmb
