Adding node servers - Polisy or Polyglot?
What is the best practice for installing node servers?  Install in Polisy or in Polyglot3?
Sorry if this has been asked before.  I searched but didn't find anything.
Edited by PSiess
Solved by MrBill
Polyglot3 is the future.  At the moment both Polyglot 2 and 3 are available for use on Polisy.  Installing new tho, you should use Polyglot 3.
https://<IP.ADDR.OF.POLISY> will land you in the Polyglot 2 interface, perhaps what you are referring to generically as "polisy".
https://<IP.ADDR.OF.POLISY>:3000 will land you in Polyglot 3 interface.
of course in either of those examples <IP.ADDR.OF.POLISY> is a place holder, you need the actual IP address of your polisy on your local network, you can't literally type <IP.ADDR.OF.POLISY>  (it might be obvious to some, but I didn't use to include this disclaimer and someone said "It doesn't work").
Obligatory "Ohhhh noooooooooooooo!"
Thanks @MrBill.  That helps a lot.
