Notification not being sent by programs
I have an ISY running version 5.3.0 and using gmail to send notifications to my phone @tmomail.net. The test function works just fine. When a notification is triggered by a program, the notification is never sent and the error log shows -50001 -19 which I believe is smtp_write_failed. Any ideas?
Solved by MClarke
I just figured out that the program will send the notification if I send it to Default. It's the customized content that fails.
It seems that the message body can't be blank. I only had it in the subject. It's working now that I added to the body of the customized content.
  • 1 month later...
Older post, but started having same problem of notifications not being sent.  Worked for the test email in ISY but didnt work for others.
I had a custom email setting for SMTP.  I tried multiple email smtps.  Program would not send notification, but worked with ISY test email.
To fix, I just use the default checkbox setting for email settings.  Works fine from programs now.
