Compatibility between Elk Module and HA
Good morning,
I was wondering if anyone here has both the Elk Module on the ISY and running the Elk service on Home Assistant ? I know they both use port 2101, but was wondering if anyone here was seeing any kinds of conflicts of the service. An example would be if the M1EXP completely loses connection with the ISY, slow service or any kind of network errors.
Solved by Michel Kohanim
@snesgenesis if you have the Elk nodes in the ISY they should show up in HA when you have the ISY integration setup. Are you attempting to have them tied to both as a backup option for something? Or just trying to have the devices in HA as well as controllable in the ISY?
I don't have Elk, but would imagine if Elk lost communication with the ISY that it probably wouldn't communicate with anything else in the same network (if you were able to have them connected simultaneously).
