Support thread for: IoX v.5.5.0
I had a similar experience adding a multisensor 7. The event log showed it as being added but no nodes showed up. I tried sync with interview but it crashed IOP with java errors and automatically restarted but still no nodes. i then shut down IOP and reopened it from the finder. It started but showed busy with the progress bar. When that finished, the nodes showed up
Gary
Gary
Thanks for the detail. I tried restarting the isy (IOP) process and restarting it, restarting the admin console as well and the nodes are still MIA. Not sure how to proceed yet - no answer from support yet.
This is just an idea...  You might look at the "DH All Devices" selection under the Z-Wave | Z-Wave X-Ray menu to see if the devices that don't appear in the device tree are in that device list.  In my case, device 2 appears in this list, but nothing shows up in the device tree.  Device 2 is a Aeotec Range Extender 7 (it was the first device I included in the network).  This won't fix anything, but you might be able to see if the device is actually included.  If a device appears in X-Ray, you can run a REST query against it, such as this:
http://192.168.1.19:8080/rest/zmatter/zwave/dh/node/2/cc/0
This returns a ton of data for an otherwise invisible device.
Interesting:
31 is the device I tried adding. I've not been able to get any battery powered device to successfully interview. So far - all the reports I've seen in the forum are similar - battery powered remotes.
By looking at this: /rest/zmatter/zwave/dh/node/31/cc/0
I see some parts where the interview was done - and others where it was not done.
Command Classes list for device 31 instance 0 [.]:
   Command Class 32 0x20 BASIC
Empty    DATA devices.31.instances.0.commandClasses.32.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.32.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.32.data.version = 0 (0x00000000)
Boolean  DATA devices.31.instances.0.commandClasses.32.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.32.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.32.data.interviewCounter = 9 (0x00000009)
Empty    DATA devices.31.instances.0.commandClasses.32.data.level = Empty
   Command Class 34 0x22 APPLICATION_STATUS
Empty    DATA devices.31.instances.0.commandClasses.34.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.34.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.34.data.version = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.34.data.security = False
Boolean  DATA devices.31.instances.0.commandClasses.34.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.34.data.interviewCounter = 9 (0x00000009)
   Command Class 86 0x56 CRC_16_ENCAP
Empty    DATA devices.31.instances.0.commandClasses.86.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.86.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.86.data.version = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.86.data.security = False
Boolean  DATA devices.31.instances.0.commandClasses.86.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.86.data.interviewCounter = 9 (0x00000009)
   Command Class 89 0x59 ASSOCIATION_GROUP_INFO
Empty    DATA devices.31.instances.0.commandClasses.89.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.89.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.89.data.version = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.89.data.security = False
Boolean  DATA devices.31.instances.0.commandClasses.89.data.interviewDone = False
Integer  DATA devices.31.instances.0.commandClasses.89.data.interviewCounter = 8 (0x00000008)
Empty    DATA devices.31.instances.0.commandClasses.89.data.dynamic = Empty
   Command Class 90 0x5a DEVICE_RESET_LOCALLY
Empty    DATA devices.31.instances.0.commandClasses.90.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.90.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.90.data.version = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.90.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.90.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.90.data.interviewCounter = 9 (0x00000009)
Boolean  DATA devices.31.instances.0.commandClasses.90.data.reset = False
   Command Class 91 0x5b CENTRAL_SCENE
Empty    DATA devices.31.instances.0.commandClasses.91.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.91.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.91.data.version = 3 (0x00000003)
Boolean  DATA devices.31.instances.0.commandClasses.91.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.91.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.91.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.91.data.maxScenes = 12 (0x0000000c)
Empty    DATA devices.31.instances.0.commandClasses.91.data.currentScene = Empty
Empty    DATA devices.31.instances.0.commandClasses.91.data.keyAttribute = Empty
Boolean  DATA devices.31.instances.0.commandClasses.91.data.slowRefresh = True
Boolean  DATA devices.31.instances.0.commandClasses.91.data.slowRefreshSupport = True
Empty    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask = Empty
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.1 = int[5]
  [00] 0
  [01] 1
  [02] 2
  [03] 3
  [04] 4
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.2 = int[5]
  [00] 0
  [01] 1
  [02] 2
  [03] 3
  [04] 4
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.3 = int[5]
  [00] 0
  [01] 1
  [02] 2
  [03] 3
  [04] 4
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.4 = int[5]
  [00] 0
  [01] 1
  [02] 2
  [03] 3
  [04] 4
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.5 = int[5]
  [00] 0
  [01] 1
  [02] 2
  [03] 3
  [04] 4
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.6 = int[5]
  [00] 0
  [01] 1
  [02] 2
  [03] 3
  [04] 4
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.7 = int[1]
  [00] 0
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.8 = int[1]
  [00] 0
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.9 = int[1]
  [00] 0
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.10 = int[1]
  [00] 0
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.11 = int[1]
  [00] 0
Int[]    DATA devices.31.instances.0.commandClasses.91.data.sceneSupportedKeyAttributesMask.12 = int[1]
  [00] 0
   Command Class 94 0x5e ZWAVEPLUS_INFO
Empty    DATA devices.31.instances.0.commandClasses.94.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.94.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.94.data.version = 2 (0x00000002)
Boolean  DATA devices.31.instances.0.commandClasses.94.data.security = False
Boolean  DATA devices.31.instances.0.commandClasses.94.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.94.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.94.data.plusVersion = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.94.data.roleType = 4 (0x00000004)
Integer  DATA devices.31.instances.0.commandClasses.94.data.nodeType = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.94.data.installerIcon = 5632 (0x00001600)
Integer  DATA devices.31.instances.0.commandClasses.94.data.userIcon = 5632 (0x00001600)
String   DATA devices.31.instances.0.commandClasses.94.data.roleTypeString = "Portable Slave"
   Command Class 112 0x70 CONFIGURATION
Empty    DATA devices.31.instances.0.commandClasses.112.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.112.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.112.data.version = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.112.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.112.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.112.data.interviewCounter = 9 (0x00000009)
Boolean  DATA devices.31.instances.0.commandClasses.112.data.preferBulk = False
Boolean  DATA devices.31.instances.0.commandClasses.112.data.noBulkSupport = True
   Command Class 114 0x72 MANUFACTURER_SPECIFIC
Empty    DATA devices.31.instances.0.commandClasses.114.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.114.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.114.data.version = 2 (0x00000002)
Boolean  DATA devices.31.instances.0.commandClasses.114.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.114.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.114.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.114.data.vendorId = 271 (0x0000010f)
String   DATA devices.31.instances.0.commandClasses.114.data.vendor = "Fibaro"
Integer  DATA devices.31.instances.0.commandClasses.114.data.productId = 8192 (0x00002000)
Integer  DATA devices.31.instances.0.commandClasses.114.data.productType = 4097 (0x00001001)
Binary   DATA devices.31.instances.0.commandClasses.114.data.serialNumber = byte[8]
         [000000000000BD69]
Empty    DATA devices.31.instances.0.commandClasses.114.data.pseudoRandom = Empty
   Command Class 115 0x73 POWERLEVEL
Empty    DATA devices.31.instances.0.commandClasses.115.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.115.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.115.data.version = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.115.data.security = False
Boolean  DATA devices.31.instances.0.commandClasses.115.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.115.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.115.data.level = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.115.data.timeout = 0 (0x00000000)
   Command Class 117 0x75 PROTECTION
Empty    DATA devices.31.instances.0.commandClasses.117.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.117.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.117.data.version = 2 (0x00000002)
Boolean  DATA devices.31.instances.0.commandClasses.117.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.117.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.117.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.117.data.state = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.117.data.rfState = 0 (0x00000000)
Empty    DATA devices.31.instances.0.commandClasses.117.data.exclusive = Empty
Empty    DATA devices.31.instances.0.commandClasses.117.data.timeout = Empty
Integer  DATA devices.31.instances.0.commandClasses.117.data.stateCap = 3 (0x00000003)
Integer  DATA devices.31.instances.0.commandClasses.117.data.rfStateCap = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.117.data.exclusiveCap = False
Boolean  DATA devices.31.instances.0.commandClasses.117.data.timeoutCap = False
   Command Class 122 0x7a FIRMWARE_UPDATE_MD
Empty    DATA devices.31.instances.0.commandClasses.122.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.122.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.122.data.version = 3 (0x00000003)
Boolean  DATA devices.31.instances.0.commandClasses.122.data.security = False
Boolean  DATA devices.31.instances.0.commandClasses.122.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.122.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.122.data.manufacturerId = 271 (0x0000010f)
Integer  DATA devices.31.instances.0.commandClasses.122.data.firmwareId = 4129 (0x00001021)
Integer  DATA devices.31.instances.0.commandClasses.122.data.checksum = 61781 (0x0000f155)
Boolean  DATA devices.31.instances.0.commandClasses.122.data.upgradeable = True
Integer  DATA devices.31.instances.0.commandClasses.122.data.fragmentSize = 32 (0x00000020)
Integer  DATA devices.31.instances.0.commandClasses.122.data.firmwareCount = 0 (0x00000000)
Empty    DATA devices.31.instances.0.commandClasses.122.data.fragmentTransmitted = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.fragmentCount = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.hardwareVersion = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.blockedDuringUpdate = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.activation = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.requestStatusStr = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.requestStatus = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.updateStatusStr = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.updateStatus = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.activationStatusStr = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.activationStatus = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.prepareStatusStr = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.prepareStatus = Empty
Empty    DATA devices.31.instances.0.commandClasses.122.data.waitTime = Empty
   Command Class 128 0x80 BATTERY
Empty    DATA devices.31.instances.0.commandClasses.128.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.128.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.128.data.version = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.128.data.security = False
Boolean  DATA devices.31.instances.0.commandClasses.128.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.128.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.128.data.lastChange = 1672958864 (0x63b75390)
Empty    DATA devices.31.instances.0.commandClasses.128.data.history = Empty
Integer  DATA devices.31.instances.0.commandClasses.128.data.history.100 = 1672958864 (0x63b75390)
Integer  DATA devices.31.instances.0.commandClasses.128.data.last = 100 (0x00000064)
   Command Class 132 0x84 WAKE_UP
Empty    DATA devices.31.instances.0.commandClasses.132.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.132.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.132.data.version = 2 (0x00000002)
Boolean  DATA devices.31.instances.0.commandClasses.132.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.132.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.132.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.132.data.interval = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.132.data.nodeId = 255 (0x000000ff)
Integer  DATA devices.31.instances.0.commandClasses.132.data.min = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.132.data.max = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.132.data.default = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.132.data.step = 0 (0x00000000)
Empty    DATA devices.31.instances.0.commandClasses.132.data.lastWakeup = Empty
Empty    DATA devices.31.instances.0.commandClasses.132.data.lastSleep = Empty
Boolean  DATA devices.31.instances.0.commandClasses.132.data.wakeupOnDemand = False
   Command Class 133 0x85 ASSOCIATION
Empty    DATA devices.31.instances.0.commandClasses.133.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.133.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.133.data.version = 2 (0x00000002)
Boolean  DATA devices.31.instances.0.commandClasses.133.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.133.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.133.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.133.data.groups = 13 (0x0000000d)
Integer  DATA devices.31.instances.0.commandClasses.133.data.specificGroup = 1 (0x00000001)
Empty    DATA devices.31.instances.0.commandClasses.133.data.1 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.1.max = 1 (0x00000001)
Binary   DATA devices.31.instances.0.commandClasses.133.data.1.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.2 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.2.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.2.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.3 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.3.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.3.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.4 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.4.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.4.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.5 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.5.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.5.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.6 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.6.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.6.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.7 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.7.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.7.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.8 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.8.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.8.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.9 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.9.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.9.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.10 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.10.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.10.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.11 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.11.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.11.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.12 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.12.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.12.nodes = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.133.data.13 = Empty
Integer  DATA devices.31.instances.0.commandClasses.133.data.13.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.133.data.13.nodes = byte[0]
   Command Class 134 0x86 VERSION
Empty    DATA devices.31.instances.0.commandClasses.134.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.134.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.134.data.version = 2 (0x00000002)
Boolean  DATA devices.31.instances.0.commandClasses.134.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.134.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.134.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.134.data.ZWLib = 3 (0x00000003)
Integer  DATA devices.31.instances.0.commandClasses.134.data.ZWProtocolMajor = 4 (0x00000004)
Integer  DATA devices.31.instances.0.commandClasses.134.data.ZWProtocolMinor = 38 (0x00000026)
String   DATA devices.31.instances.0.commandClasses.134.data.SDK = "6.51.09"
Integer  DATA devices.31.instances.0.commandClasses.134.data.applicationMajor = 3 (0x00000003)
Integer  DATA devices.31.instances.0.commandClasses.134.data.applicationMinor = 2 (0x00000002)
Integer  DATA devices.31.instances.0.commandClasses.134.data.hardwareVersion = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.134.data.firmwareCount = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.134.data.32 = 0 (0x00000000)
Integer  DATA devices.31.instances.0.commandClasses.134.data.34 = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.134.data.86 = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.134.data.89 = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.134.data.90 = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.134.data.91 = 3 (0x00000003)
Integer  DATA devices.31.instances.0.commandClasses.134.data.94 = 2 (0x00000002)
Integer  DATA devices.31.instances.0.commandClasses.134.data.112 = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.134.data.114 = 2 (0x00000002)
Integer  DATA devices.31.instances.0.commandClasses.134.data.115 = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.134.data.117 = 2 (0x00000002)
Integer  DATA devices.31.instances.0.commandClasses.134.data.122 = 3 (0x00000003)
Integer  DATA devices.31.instances.0.commandClasses.134.data.128 = 1 (0x00000001)
Integer  DATA devices.31.instances.0.commandClasses.134.data.132 = 2 (0x00000002)
Integer  DATA devices.31.instances.0.commandClasses.134.data.133 = 2 (0x00000002)
Integer  DATA devices.31.instances.0.commandClasses.134.data.134 = 2 (0x00000002)
Integer  DATA devices.31.instances.0.commandClasses.134.data.142 = 3 (0x00000003)
Integer  DATA devices.31.instances.0.commandClasses.134.data.152 = 1 (0x00000001)
   Command Class 142 0x8e MULTI_CHANNEL_ASSOCIATION
Empty    DATA devices.31.instances.0.commandClasses.142.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.142.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.142.data.version = 3 (0x00000003)
Boolean  DATA devices.31.instances.0.commandClasses.142.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.142.data.interviewDone = False
Integer  DATA devices.31.instances.0.commandClasses.142.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.142.data.groups = 13 (0x0000000d)
Empty    DATA devices.31.instances.0.commandClasses.142.data.1 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.1.max = 1 (0x00000001)
Binary   DATA devices.31.instances.0.commandClasses.142.data.1.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.2 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.2.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.142.data.2.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.3 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.3.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.142.data.3.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.4 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.4.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.142.data.4.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.5 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.5.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.142.data.5.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.6 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.6.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.142.data.6.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.7 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.7.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.142.data.7.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.8 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.8.max = 5 (0x00000005)
Binary   DATA devices.31.instances.0.commandClasses.142.data.8.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.9 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.9.max = 0 (0x00000000)
Binary   DATA devices.31.instances.0.commandClasses.142.data.9.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.10 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.10.max = 0 (0x00000000)
Binary   DATA devices.31.instances.0.commandClasses.142.data.10.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.11 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.11.max = 0 (0x00000000)
Binary   DATA devices.31.instances.0.commandClasses.142.data.11.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.12 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.12.max = 0 (0x00000000)
Binary   DATA devices.31.instances.0.commandClasses.142.data.12.nodesInstances = byte[0]
Empty    DATA devices.31.instances.0.commandClasses.142.data.13 = Empty
Integer  DATA devices.31.instances.0.commandClasses.142.data.13.max = 0 (0x00000000)
Binary   DATA devices.31.instances.0.commandClasses.142.data.13.nodesInstances = byte[0]
   Command Class 152 0x98 SECURITY
Empty    DATA devices.31.instances.0.commandClasses.152.data = Empty
Boolean  DATA devices.31.instances.0.commandClasses.152.data.supported = True
Integer  DATA devices.31.instances.0.commandClasses.152.data.version = 1 (0x00000001)
Boolean  DATA devices.31.instances.0.commandClasses.152.data.security = True
Boolean  DATA devices.31.instances.0.commandClasses.152.data.interviewDone = True
Integer  DATA devices.31.instances.0.commandClasses.152.data.interviewCounter = 9 (0x00000009)
Integer  DATA devices.31.instances.0.commandClasses.152.data.scheme = 0 (0x00000000)
Binary   DATA devices.31.instances.0.commandClasses.152.data.secureNodeInfoFrame = byte[9]
         [855B705A728E868475]
Boolean  DATA devices.31.instances.0.commandClasses.152.data.securityAbandoned = False
Boolean  DATA devices.31.instances.0.commandClasses.152.data.canStream = False
Empty    DATA devices.31.instances.0.commandClasses.152.data.toFollow = Empty
I tried emailing support@universal-devices.com and have not got the usual response about a ticket being opened and the ticket was not opened in the https://www.universal-devices.com/my-tickets/ portal.
You can only create tickets using the web interface, sending to support email doesn't work anymore, or it hasn't worked for me for a while.
Sent from my Pixel 6 Pro using Tapatalk
1 hour ago, MWareman said:
Interesting:
I have had the same problem trying to add a Fibaro 601 remote.  It goes through the interview process and closes without adding any nodes.  I believe the battery devices don’t stay awake long enough to let the interview complete.  Has anyone had success with adding a Fibaro remote?  If so, please let us know the details for adding this device.
Got a response to my ticket - an issue has been identified that would affect multiple devices. No specifics yet on which devices but the fix is in to allow the nodes to be seen. Not clear yet on the lack of interviews though.
Also noted: the lack of writing to the ZWAY.LOG file is an issue in log rotation. I had restarted the ISY binary (which got logging going again) and this is the correct temporary resolution until the root issue can be located.
Well I'm excited. :)
Aside from critical breaking issues, the rest of my experience with ZMatter has been excellent.  Even my Insteon network is working much better, and there's really no cause for that.
I'm likewise having difficulty adding a Zooz Zen16 device. I only see a power switch and three 'basic association' nodes, when with the 500 series dongle on the ISY I had the expected three inputs and three outputs which worked properly. Z-Wave X-ray shows "Interview Not done" for each attempt to add the device though I'm able to set parameters. Hoping this gets fixed in the next update, this is one of the most important devices in my system.
edit: After restoring from the ISY 994i backup and attempting to add this device, as the afternoon progressed Insteon functionality just stopped working, and then I could no longer find the eisy in the finder. This seems to mirror some of the reports I've seen in other threads. I think I'll go back to my original functioning setup and come back to this project in a few months once some of these bugs are worked out.
Edited by MDoughney
update with latest events
On 1/1/2023 at 4:08 PM, brians said:
I also tried parameter 8 and 17 to set the auto off to 1 second for relay 2... to simulate a momentary press. This did not work. I currently have a program that turns off relay 2 button after 1 second for garage door button but before I programmed the Zen17 to handle it on its own. Seems like configuration parameters are not working correctly still for me anyways. In case of my garage door, I have the button on relay 2 and the garage door sensor on input 1 (which both will trigger the relay)... Currently when garage door is closed the relay 1 sensor shows On. I have adjusted programs to compensate.
Since I am currently using both my Zen17s, It is difficult for me to experiment with them without breaking other things. Maybe UD can test Zen17 on their end and make sure all the parameters work, including one to change input type parameter 2 and parameter 3 for each relay.
Below example when I used Zooz ZWave dongle, I set to 7 and after excluding/including again shows a device type named barrier for the door and shows as open/close status not on/off.
Here is the instructions I used before on Zooz Z-Wave dongle which work fine...
For Garage Door
Will hook up the switch and the sensor on separate sensor/relays just in case the isolation is not set correctly.
Reset
Include in ISY
Set for Door Open/Close sensor
Set Parameter 2 to 7
Set Parameter 3 to 7
Exclude/Include in ISY
This will add additional nodes each sensor
Set Parameter 10 to 0
Set Parameter 11 to 0
This isolates the relays being triggered from the inputs
Garage Door Sensor (Sensor 1)
ZW XXX.1 Barrier 1
Garage Door Switch (Relay 2)
ZW XXX.2 Binary Switch
To set simulate momentary 1 second
Parameter 8: auto turn-off timer for Relay 2
Parameter 17: auto turn-off timer unit for Relay 2
Set Parameter 17 to 1 (seconds)
Set Paramter 8 to 1 (1 second) *** must use 4 byte to write
Parameter 20: Reverse the reported values for your selected input on S2 C terminals (select same value as parameter 3 eg. 7)
(not reversed set to 0)
Closed on Sensor 1 will show door closed
Set Parameter 20 to 7 if your door sensor switch is NO when closed.
I did some tests tonight and was able to set parameter 3 to 3 which has built in momentary garage door setting on button so it turns off relay 2 after a few seconds. I have garage door open sensor on relay 1. The issue seems to be with anything with parameter 4 and above, it does not show the extra nodes. The Zooz instructions say to either exclude/include or re-interview. Neither work. Because of this we cannot get extra parameters and isolate the inputs.
Note that it is important to set the parameter using the one ZWave node that contains the parameter option... right clicking on a different node and selecting zwave write configuration parameter did not seem to work for me. In case of Zen17 specifically it is the node named default ZY xxx Binary Switch. The ones named ZY xxx.1 or .2 do not work.
Hopefully UDI can fix this Zen17 configuration issue since this is a very useful and popular device... would be nice to be able to separate the inputs from the relay and set different types of contacts. If this was possible to isolate, I could have the switch on relay 2 and sensor on input 2 and could run two separate doors, or maybe other sensors and switches. It worked fine before with Zooz dongle so thing there is just something overlooked hopefully.
Edited by brians
On 12/17/2022 at 3:25 PM, Bumbershoot said:
A couple of gotcha's with GoControl/Linear Garage Door Openers.  I have two of these devices and they both operate similarly.  They included fine, but the devices never showed up in the device list.  They were excluded/included again, and this time with the "S2 Access" box unchecked (only S0 is checked), and the interview completed and devices appeared in the device list.  They control the doors just fine, but the "Status" value never appears.  I changed batteries a couple of times in the tilt sensors, but to no avail.
I am experiencing the same problem - status never updates. gocontrol GD00Z-8 garage door controller, 5.5.3, ZMatter. Did you file a ticket?
If I issue an open comand or a close command, it works, but my programs that are using the status value do not work, of course.
Edited by wmcneil
additonal info
No, but I did send @Chris Jahn some data of these in operation from the Z-Wave log, at his request.  I think UDI have what they need.
