Controls not working
tazman
Go to solution Solved by Panda88,
I have not really used this node server for anything but to show status until today I tried to setup so I could turn the seat heaters on before heading out without opening the app on my phone but the commands don't seem to work but I can see the state change from action done in the app when I update data. Below is the error I see in the log
2022-12-16 20:04:48,965 Command udi_interface.interface ERROR interface:_handleInput: _parseInput: failed climate1.runCmd(SEAT1) unhashable type: 'dict'
Traceback (most recent call last):
File "/var/polyglot/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 795, in _handleInput
self.nodes_internal[item['address']].runCmd(item)
File "/var/polyglot/.local/lib/python3.9/site-packages/udi_interface/node.py", line 165, in runCmd
fun(self, command)
File "/var/polyglot/pg3/ns/EDITED_5/TeslaEVClimateNode.py", line 225, in evSetSeat0Heat
self.TEV.teslaEV_SetSeatHeating(self.EVid, 0, seatTemp)
File "/var/polyglot/pg3/nsEDITED_5/TeslaCloudEVapi.py", line 856, in teslaEV_SetSeatHeating
seats = {{'frontLeft':0},{'frontRight':1},{'rearLeft':2},{'rearCenter':4},{'rearRight':5} }
TypeError: unhashable type: 'dict'
38 minutes ago, Panda88 said:
Found a bug - 0.2.16
I have been working on furhter improvements but not released yet
I sent you a PM with a bigger log file no rush with this if you can get it working. Thanks for looking into this.
18 minutes ago, Panda88 said:
I believe I fixed it already - it was one of my first python projects and I have no way to test the control code, as I do not have a car to test it on
Sorry the seat heaters still are not working I sent you a log last night on version 0.2.17
Just to put some information here in case someone else has issues. What I have found is the Precondition needs to be activated for the seat heaters to operate but the controls for the seat heaters are still not quite right.
10 minutes ago, Panda88 said:
Is there any chance I can get you to try the release in non-production store - There are some fixes there
I want to release it but do not have a good way to test
I can check it out later tonight after work. Thank you for working on this.
Thanks - I will be travelling so out of reach for a little while - Not too urgent to check it out - just wanted to get the latest changes in - It seems Tesla changed how they report sleep and this addresses this and some other fixes
Edited by Panda88
The one in the non-production store will not install for me there is an Activate button under purchase but when I click  the button nothing happens. Maybe someone else can see if they can install it?
I don't know it says it is free and the other ones that say free the button says install? Maybe because I already did the trial on the original one it will not allow it?
      379.8k
