Custom Status Names
In MobileLinc Pro there is a nice feature that allows you to map a status to another word
As an example for an IOLink
  • if set to On, show as Closed
  • if set to Off, show as Open
Any way to do that w/ UD Mobile?
Ya I just started doing more with UD Mobile here is example of sorta what you want.
I even made my home screen folder display different status of everything if a light is on in a room it shows Yellow and displays On. In particular, if garage door is open/closed and lights on/off the room folder changes color of door appropriately. If I open the door with light on I make it sorta orange color and if open and no light on it is red (not shown).
IMG_9805.thumb.PNG.be3d9e036debd313450dc8fcd81c7898.PNGIMG_9808.thumb.PNG.6230e405d219b95315aa23b6e65cd306.PNG
Then I also monitor my septic lift pump, it displays status of a couple leak sensors labelled OK, and will turn red and say Leak. Also if pump is running and how many times it ran today.
Edited by brians
I got the basics working, TY.  When I rearrange the icons I can't seem to have 2 icons in a row, only 3.  I want to get to something like the attached.  But it will only let me do this
Edited by gages97
I figured it out.  You create some blanks by adding and setting icon to empty.  Then move things around
Or you can change the SPAN from default to 2 or 3. See my example below for security. UD mobile is extremely powerful once you figure it out. you can have your own custom names for displays, you can have one device be the display, but a program or other device be the action when pressed. very versatile.
