eisy Migration and Network Resources
I was able to migrate from my long-time (and reliable) isy & Polisy setup to eisy only.
Although I did have some issues, (no doubt some were self-inflicted) I managed to get everything working except for my many network resources. I finally stumbled upon simply opening each one up as if to edit it, and then re-saving it. I made no changes, but once it got saved it would work.
My last unresolved issue is that I can't get my wake-on-lan commands to work. At the moment, hat's is not as big of a deal as the network resources not working. I just use those to turn on my TVs as part of a much larger scene automation.
Solved by bigDvette
That point was actually in the migration wiki.  I have found you  have to do this basically any time you restore a backup.
OK. I missed that part.
That's what I get for reading instructions as I am doing something rather than reading them all the way through beforehand.
You need a node server to do that now.  See this:
Perfect! I probably saw this when it was posted, but since I wasn't using IoP at the time, I ignored it. All is good now.
