shbatm Posted February 7, 2023 Author Share Posted February 7, 2023 1 hour ago, rktortr said: Thanks for anything you can do, whenever appropriate. https://github.com/home-assistant/core/pull/87650 Link to comment
vbPhil Posted February 7, 2023 Share Posted February 7, 2023 On 1/15/2023 at 10:44 AM, shbatm said: Next month they'll all come in as number entities. The only thing that setting will control is which get enabled by default. I'm confused by this. I'm using version core-2023.2.2. I'm reading back through this thread to understand the changes that were put in. Did I miss something or get out of order in the timeline? My variables came over as numbers, but disabled, regardless of what value is in the Integration Config setting for Variable Sensor String. Link to comment
shbatm Posted February 7, 2023 Author Share Posted February 7, 2023 (edited) 1 hour ago, vbphil said: My variables came over as numbers, but disabled, regardless of what value is in the Integration Config setting for Variable Sensor String. Just enable the ones you want one by one by clicking on the entity and going to settings. The config setting only effects the first time the entities are created, so if you changed the setting after the entities were created it won't go back and enable/disable variables that already existed (that's just a function of HA) Edited February 7, 2023 by shbatm Link to comment
Mecheng70 Posted February 8, 2023 Share Posted February 8, 2023 @shbatm Noticed this: if the nodes in eisy have not been queried (system reboot) then they are loaded as sensors until each one is queried and HA is restarted. This also removes all the icons that were selected in the entities section. Can we load them as what they are and not assume that they are sensors? Link to comment
rktortr Posted February 8, 2023 Share Posted February 8, 2023 10 hours ago, shbatm said: https://github.com/home-assistant/core/pull/87650 Perfect. Update installed and network resources now show up and work as intended. Thank you VERY much. Link to comment
shbatm Posted February 9, 2023 Author Share Posted February 9, 2023 20 hours ago, Mecheng70 said: Noticed this: if the nodes in eisy have not been queried (system reboot) then they are loaded as sensors until each one is queried and HA is restarted. Can you capture /rest/nodes and /rest/status in that scenario and post/send to me? Does setting a full system query program to run at reboot fix the issue? 20 hours ago, Mecheng70 said: Can we load them as what they are and not assume that they are sensors? Home Assistant's ISY integration doesn't "remember" anything about what type an entity is on each load. It sorts them based on the information provided from the ISY each time--that's the only dependable way to pick-up new (or purposefully changed) nodes, without creating a whole bunch of junk on the Home Assistant side. Home Assistant stores the custom names and icons based on matching "(platform/type, isy994 domain, isy_mac__node_address)" combos after evertyhing is loaded, but if that node doesn't get sorted the same (or exist) on the next load, those remnants are removed. -- This part can be disabled (it's the old cleanup entities service), but leaves the issue of those remnants piling up. Disabling it this case would keep the preferences when you query and reload, but you'd end up with duplicate sensor entities with unknown states after a reboot. Link to comment
Mecheng70 Posted February 9, 2023 Share Posted February 9, 2023 I will remember to do that next time. Working with Chris tonight to troubleshoot some zwave issues. If we reboot then I'll capture it. Thanks for the explanation. I get it. Appreciate it. Link to comment
Mecheng70 Posted February 9, 2023 Share Posted February 9, 2023 Just updated to 4.0.4 in HA and after reloading there are several devices that have the ? on the icon in the lovelace. In the entities panel: However, all devices are showing up and operational in UDI Mobile. Link to comment
Mecheng70 Posted February 9, 2023 Share Posted February 9, 2023 11 hours ago, shbatm said: Can you capture /rest/nodes and /rest/status in that scenario and post/send to me? Does setting a full system query program to run at reboot fix the issue? I can't confirm this. However, I did just run the query due to the missing or not offered devices in the previous post. Will confirm if that works or not. Link to comment
vbPhil Posted February 9, 2023 Share Posted February 9, 2023 1 hour ago, Mecheng70 said: Just updated to 4.0.4 in HA and after reloading there are several devices that have the ? on the icon in the lovelace. I'm following along with this thread and you confused me with this statement. What was updated to 4.0.4? Link to comment
Mecheng70 Posted February 9, 2023 Share Posted February 9, 2023 7 minutes ago, vbphil said: I'm following along with this thread and you confused me with this statement. What was updated to 4.0.4? Apologies. The UDI integration in HA. Kind of the beta site. Link to comment
shbatm Posted February 9, 2023 Author Share Posted February 9, 2023 (edited) 26 minutes ago, vbphil said: I'm following along with this thread and you confused me with this statement. What was updated to 4.0.4? He was referring to this: @Mecheng70I noticed a few things missing too last night. I'll have to pull the release and investigate. Edited February 9, 2023 by shbatm 1 Link to comment
brians Posted February 23, 2023 Share Posted February 23, 2023 Is there a way to have multiple ignores in the ignore string?. I currently use HomeBridge, but think HA with this plugin would be a better way to do moving forward. I usually don't rename extra zwave nodes so would ignore "zy ". I also have a few other keyboards I ignore.. I don't really feel like renaming all my devices to place "{IGNORE ME}" or whatever I change it to just for this, and multiple ignores would solve the issue. Link to comment
shbatm Posted February 23, 2023 Author Share Posted February 23, 2023 (edited) 51 minutes ago, brians said: Is there a way to have multiple ignores in the ignore string? No, but you can also ignore entire folders: I have "[i]" set as my string. I use rooms for my top-level folders and if there's things I don't want imported to HA, I add them to a subfolder named "[i]". /Bedroom/Node 1 - imported /Bedroom/[i]/Node 2 - not imported You can also just Disable the node/devices individually inside Home Assistant. Edited February 23, 2023 by shbatm 1 1 Link to comment
asbril Posted March 2, 2023 Share Posted March 2, 2023 @shbatm Since the latest ISY Integration update in HA, my ISY dimmers (lights and fan controllers) no longer show up as dimmers, only as ON/OFF. You have any idea what nay have happened ? Link to comment
vbPhil Posted March 2, 2023 Share Posted March 2, 2023 I updated to HA 2023.3.0 this morning and although I haven't noticed any operational issues, I did just see a couple things. The ISY integration is reporting that I have 699 entities. Looking at the entities list it now shows that a simple Insteon Applicance link on/off switch ends up with 6 entities. Wow! I'm not sure if that's related to the update. I'm getting this warning in the system log: The "isy994.reload" service is deprecated and will be removed in 2023.5.0; use the "homeassistant.reload_core_config" service and pass it a target entity ID of "this device" 3:18:48 PM – (WARNING) Universal Devices ISY/IoX Link to comment
vbPhil Posted March 2, 2023 Share Posted March 2, 2023 I just noticed another error in the log: Quote TemplateError('TypeError: 'NoneType' object is not subscriptable') while processing template 'Template("{{ state_attr('sensor.zy_022_energy_meter','total_energy_used')[:-3]}}")' for attribute '_attr_native_value' in entity 'sensor.bathroom_energy_used' I have 4 z-wave switches that have an "energy used" attribute that I was capturing by template entries in the configuration yaml. I'm still getting data on my dashboard sensors displays but these errors are in the log for all 4 of the switches. Quote Error while processing template: Template("{{ state_attr('sensor.zy_023_energy_meter','total_energy_used')[:-3]}}") Error while processing template: Template("{{ state_attr('sensor.zy_022_energy_meter','total_energy_used')[:-3]}}") Error while processing template: Template("{{ state_attr('sensor.zy_005_energy_meter','total_energy_used')[:-3]}}") Error while processing template: Template("{{ state_attr('sensor.zy_026_energy_meter','total_energy_used')[:-3]}}") Error while processing template: Template("{{ state_attr('sensor.zy_027_temperature','temperature')[:-2]}}") Any ideas what might be happening? Link to comment
vbPhil Posted March 3, 2023 Share Posted March 3, 2023 5 hours ago, vbPhil said: Any ideas what might be happening? Another update was released, 2023.3.1. All my error and warning messages went away. Go figure. Still have a huge number of entities, 699. Link to comment
Mecheng70 Posted March 3, 2023 Share Posted March 3, 2023 15 minutes ago, vbPhil said: Another update was released, 2023.3.1. All my error and warning messages went away. Go figure. Still have a huge number of entities, 699. You can hide them or just ignore them. I have 500+ and hide a lot of them. Don't think it's a big issue. Link to comment
shbatm Posted March 3, 2023 Author Share Posted March 3, 2023 8 hours ago, vbPhil said: Still have a huge number of entities, 699. https://forum.universal-devices.com/topic/40165-help-why-insteon-appliance-link-has-6-entities/?do=findComment&comment=359311 Link to comment
shbatm Posted March 3, 2023 Author Share Posted March 3, 2023 13 hours ago, vbPhil said: Quote Error while processing template: Template("{{ state_attr('sensor.zy_027_temperature','temperature')[:-2]}}") Any ideas what might be happening? Try pasting into the Developer Tools > Template tab to see if you can get a better idea of what the error is. 1 Link to comment
vbPhil Posted March 3, 2023 Share Posted March 3, 2023 45 minutes ago, shbatm said: https://forum.universal-devices.com/topic/40165-help-why-insteon-appliance-link-has-6-entities/?do=findComment&comment=359311 yikes my own topic! Sorry about that. My memory is failing as it's getting harder to keep up with all this new technology I'm learning. Link to comment
