Virtual Devices
I have a few Homekit devices specifically for the Carplay integration, but I would like to fire events in IoX with them.  I have the ability to control IoX devices based on Homekit events via the ISY plugin for Homebridge.
I thought I was going to be able to use an empty scene for this, but you can't check the on/off status of a scene in a program.
Is there a way to create a "virtual" switch device in IoX for this?
Solved by MrBill
There is a node server called virtual that lets you change a variable into a device node.
Scene's don't actually have an on/off status which is why you can't check it via a program.
