How to turn a device OFF for 6 hours then back ON?
stef2
Kingwr,
The other thing is the true/false status of a program. Outside of that, I am not sure that knowing all of the nuances of a trigger event really matters.
Basically, a trigger event has the potential to kill a running then/else, restart a running then/else, and change the true/false status.
Lou
Also, my understanding is that much of this is only applicable if the THEN or ELSE branch contains a WAIT or a REPEAT. This was mentioned before, but was lost in the last few posts. So, just to make sure we are all clear, the only time a subsequent triggering of a program may occur that would pre-empty the currently running program is when there is a WAIT or a REPEAT, I think.
I would say that "preempting" s the key word here. If there isn't a WAIT or a REPEAT, the THEN or ELSE will most likely execute "almost immediately". Therefore there wouldn't be anything to stop. However, if you have used a program as a variable, then this could be affected as the true/false would change. Could have a much different effect on your program than you expected. Also, as I pointed out in an earlier post, using the climate module and checking for light level, I found that the IF statement was evaluated and the THEN statement was executed every time that the weatherbug was pollled. Since I was just using the program to turn off a light, it wasn't a big deal, but it did send out an OFF command every 60 seconds which was totally unneccessary and flooding the power line.
Did this Wiki update take place? If so, where is it?
Bill
Hi guys,
All very good questions. I will put something together for the Wiki based on this thread.
Thanks, Rand
In short, I would love to see the owners manual, or at least the wiki have two sections back to back.
1) understanding true/flase
2) understanding triggers
      378.3k
