Program assistance variable from ECOWITT node server
Request for info
When writing an email body I want to include the temperature from an ECOWITT node server TEMP/Humidity
Doing this for an Insteon thermostat works as below.
${sys.node.2F 7D 2 1.name}
   Temperature: ${sys.node.2F 7D 2 1.ST}F
   Humidity:    ${sys.node.2F 7D 2 1.CLIHUM}
What would be the format for a Node Server device like my node003_wh31_3  device?
Solved by Bumbershoot
7 minutes ago, JMcKain said:
Request for info
Here's what the variable substitution value looks like for an ECOWITT moisture sensor:
${sys.node.n005_wh51_1.ST}
You can click on the "Nodes" button on your node server to see the values for each device.
Below are the possible values for the moisture sensor:
14 hours ago, bpwwer said:
Humidity:    ${sys.node.node003_wh31_3CLIHUM}
you might be missing a .
Humidity:    ${sys.node.node003_wh31_3.CLIHUM}
