Polisy DB9 to PLM
alphapenguin
Go to solution Solved by Geddy,
I am finally setting up my polisy pro to use the ISY/IoX.
I had to buy a new DB9 to Rj45 cable from Amazon.
I keep getting
  image.png.d7168c6fa8c2289fa626bc5275f101
I have reset the system a few times and no go. I know my PLM works as it functions with the ISY994i
OIKWAN DB9 to RJ45 Console Cable,Compatible with Cisco Router Switch CAB-CONSOLE-RJ45 https://a.co/d/fpAV4QL
It seems to be a standard premade cable so I am thinking the cable is bad, the DB9 port is bad or the pinouts are correct?
I bought a
StarTech.com DB9 to RJ45 Modular Adapter - F/F - Serial adapter - DB-9 (F) to RJ-45 (F) - GC98FF, Black https://a.co/d/98YBVT5
And will come today. Hopefully it works.
Alex
It's might be standard for console but not necessarily for PLM. There is a post that someone used to convert console USB adapter by re-crimping RJ45 connector. Search for it. There are only 3 wires I think. You should be able to crimp this cable if you know how.
The PLM only uses three wires and the pin out is unique.
So you have to use the correct  three wires in the DB9 to RJ45 serial adapter for the connections.
4 hours ago, alphapenguin said:
Hopefully it works.
Make sure you search for "pin out" information. This is one that I book marked a while back from @Brian H to help describe what connects where:
There are a lot of posts. Perhaps the easiest way to find them/others is using Google Site Search since some might be archived and not showing up in the forums search function.
Thanks all.
I didnt have a way to test continuity on the pins so I wasnt sure which corresponded with what. I did end up getting the:
in the mail today.
after some reading and trial and error, I found this PINOUT:
https://www.universal-devices.com/product/serial-plm-kit/
Being partially color blind it was a pain trying to figure out what the color on the right was. I thought it was red. it wasnt working, so I asked my 9 year old daughter, and she told me it was brown.
Anyway, it works now.
THanks
Alex
11 hours ago, alphapenguin said:
Thanks all.
in the mail today.
THanks
Alex
Best to use only the three needed wires. As there are other signals on the PLM RJ45 jack that can possible connected to other things and effect the operation. Like the unused TTL level In and out signals. Insulate and don't connect to anything.
Thanks! Well I didn't insulate them. I wonder if that will be a issue. Maybe short the PLM?
Exactly. There are other signals on the PLM RJ45 pins that carry voltage and TTL level signals which may permanently damage the PLM if shorted out.
      378.5k
