PG3 Not Working On Mobile
My PG3 was previously setup and working in mobile but I noticed today that it wasn't in mobile and was prompting me to add it. After I added it, every time I click "test connection" it says that it must be saved first, but it is saved. Then, if I click "Polyglot V3" in the Admin Dashboard, it will crash the app every time.
Oh I don’t seem to have that on iOS. What is the purpose is that anyways to administer it without webpage ?
Hi @gregkinney,
Issue is known for some newer Android version, caused by intent crash in PAHO MQTT Library.  I'll try to get it fixed in the next update.
@brians,
Currently only in Android and must be on local network. We are working a PG3 portal integration so both remote and local connections can be established. This will change MQTT topics at which point the Android integration will need to be modified. So the local only version will not be ported to iOS although will likely be first in new integration.
10 hours ago, Javi said:
Hi @gregkinney,
@brians,
@Javi
I was having the same issue with UD Mobile crashing. I was finishing up migrating to eisy and didn't want to muddy the waters, so I set it aside.
As a suggestion, maybe UD could consider setting up a known issues page across the product line?
1 hour ago, DennisC said:
@Javi
With UD Mobile there are public get repos with issues.  I though I added this issue, but it was not listed. Added issue https://github.com/UniversalDevicesInc/UD-Mobile-Android/issues/43
