AlexE Posted March 11, 2023 Posted March 11, 2023 Before upgrading to IoX 5.5.9 I successfully added two ZOOZ ZEN15 plugs with energy meter to my eisy. I was trying to add another one today and the Energy Meter is missing. I tried several times with the same result. I could add it to my polisy which does not have z-matter enabled and the energy meter shows up so I assume the device is ok. I was wondering whether I am the only one encountering this issue? Thanks
DennisC Posted March 12, 2023 Posted March 12, 2023 On 3/11/2023 at 11:53 PM, Poporo said: Before upgrading to IoX 5.5.9 I successfully added two ZOOZ ZEN15 plugs with energy meter to my eisy. I was trying to add another one today and the Energy Meter is missing. I tried several times with the same result. I could add it to my polisy which does not have z-matter enabled and the energy meter shows up so I assume the device is ok. I was wondering whether I am the only one encountering this issue? Thanks Expand Have you tried Synchronize with Interview? Did you exclude before include?
AlexE Posted March 12, 2023 Author Posted March 12, 2023 Yes I did - I am not sure whether Synchronize with interview actually does anything - is there supposed to be some progress feedback? Thanks for helping.
DennisC Posted March 12, 2023 Posted March 12, 2023 On 3/12/2023 at 3:03 PM, Poporo said: Yes I did - I am not sure whether Synchronize with interview actually does anything - is there supposed to be some progress feedback? Thanks for helping. Expand Not sure which question you said yes to? Did you exclude before include? You need to open Event Viewer and set on level 3 to see what is happening. Its under Tools - Diagnostics. Open Event Viewer and try again.
DennisC Posted March 12, 2023 Posted March 12, 2023 On 3/12/2023 at 3:11 PM, Poporo said: Both yes That's the output Expand Unless someone else has another suggestion, the only options I can see are: 1. I don't know if this makes a difference, but which synchronize with interview did you complete? One is reached by right clicking on the device, the other is from the top ZWave menu, Synchronize - New & Deleted with Interview. Since the wording is different, may they perform slightly different? If you try New & Deleted with Interview, I would suggest backing up ZWave settings first, then a complete backup. That way if something else is deleted you can restore. Leave event viewer open while doing this. 2. Try right clicking on device and write changes - leave event viewer open while doing this. 3. Exclude device and then include device and see if it does better - leave event viewer open while doing this. 4. Open support ticket with UD.
Solution AlexE Posted March 12, 2023 Author Solution Posted March 12, 2023 Thanks a lot - I moved the plug a little closed to the eisy (it was pretty close already anyway - just moved it 6ft) but that did the trick. Could have tried that earlier .... Thanks again!
DennisC Posted March 12, 2023 Posted March 12, 2023 Glad you got it working. I think this is the first time I heard of a range issue on eisy. Is your ZMatter dongle buried or surrounded by something that could be interfering?
AlexE Posted March 12, 2023 Author Posted March 12, 2023 not really - it's in a quite central open spot - I added the other devices from the same original location before moving and it worked. My guess it's that ZEN15.
