Support Thread: 5.0.16C (ISY994)
12 minutes ago, Michel Kohanim said:
@simplextech,
Or, who made it vanish :)
I think you're suggesting you did it? hmmm... :)
2 hours ago, Adam Getchell said:
I have recently upgraded from 5.0.16 to 5.0.16b.  I am now getting false opens on some of my window sensors.  Happens on about have the sensors and happens about once a day.  All batteries are new and have been running without issues on previous versions.  Could the issue be related to the new "Barrier" nodes?
Apparently in 5.0.16B the heartbeat node signal is being interpreted as an open signal by the ISY.  UDI is aware of this problem and it will be corrected in the next ISY firmware update which should be in a couple of weeks.  Currently there's no workaround.
What is the model and firmware version of your sensors?
5.0.16B is working great for me ... with one possible exception...
I have no reason to believe this is a problem specific to 5.0.16b but also no way to know it is more general.
I tried to view the error log from the Tools menu in Admin Console and the cursor turns into a circular "working" icon but other than that nothing happens-- for over 9 hours...  Admin console functionality is fully available with the funny cursor.
I vaguely remember that some months back I increased the size of the error log so maybe the problem is related to that.
I am open to any suggestions that would help diagnosis.    I don't really have a serious need to look at the error log, so I could try to clear it and then see what happens.
Happy New Year!
Happy New Year!
I know it is basics but just a thought you are using the 16b console? I have not experienced what you have yet. Maybe try & reboot and try again if so.
Perhaps clear the log if you don't need it and then see if it loads.  I view my logs through the portal mostly and I haven't had a problem.
Today when I woke up I found that the ISY no longer was able to communicate over ZWave. All zwave devices are marked as offline all of the sudden. I tried rebooting the ISY994 but it made no difference. And we're talking about Aeotec Repeaters, GE Outlets, Aeotec Motion sensors with USB power, Fibraro LED controllers, essentially everything which should have been working. And when I move one of the repeaters close and press the button to do a mesh health check (it will simply try to communicate with the ISY) it shows red. It's as if the ZWave card is fried.
I'm running 5.0.16B and I had removed and re-paired all zwave devices after that. And yesterday it was working fine. Today I cannot even heal the network because it thinks no devices are responding.
This is the level 3 log from healing:
Elapsed 00:00:07.940 : Loading Variables
Elapsed 00:00:08.363 : Loading Node Definitions
Elapsed 00:00:08.610 : Loading Nodes
Elapsed 00:00:10.171 : Creating Widgets
Elapsed 00:00:11.929 : Creating Widgets Complete
Fri 01/03/2020 10:05:23 AM : Starting Subscription
Fri 01/03/2020 10:05:24 AM : Completing initialization
Fri 01/03/2020 10:05:24 AM : Refreshing Status
Fri 01/03/2020 10:05:25 AM : Refreshing Views
Fri 01/03/2020 10:05:27 AM : [     ZW003_1]      ERR   1
Fri 01/03/2020 10:05:27 AM : [ZW-TX-FAILED] enc=Fail uid=3.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:05:32 AM : [ZW-TX-FAILED] enc=Fail uid=3.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:05:38 AM : [ZW-TX-FAILED] enc=Fail uid=3.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:05:43 AM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:05:48 AM : [     ZW012_1]      ERR   1
Fri 01/03/2020 10:05:48 AM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:05:48 AM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Fri 01/03/2020 10:05:49 AM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:05:49 AM : [ZWAVE-TX ZW012_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:05:54 AM : [D2D EVENT   ] Event [ZW012_1] [ERR] [0] uom=0 prec=-1
Fri 01/03/2020 10:05:54 AM : [     ZW012_1]      ERR   0
Fri 01/03/2020 10:05:54 AM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:05:54 AM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:05:54 AM : [ZWAVE-TX ZW012_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:05:59 AM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x33.03 SWITCH_COLOR
Fri 01/03/2020 10:05:59 AM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Fri 01/03/2020 10:06:00 AM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:00 AM : [ZWAVE-TX ZW012_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:05 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:06:05 AM : [D2D EVENT   ] Event [ZW012_1] [ERR] [1] uom=0 prec=-1
Fri 01/03/2020 10:06:05 AM : [     ZW012_1]      ERR   1
Fri 01/03/2020 10:06:05 AM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x33.03 SWITCH_COLOR
Fri 01/03/2020 10:06:05 AM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Fri 01/03/2020 10:06:05 AM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:05 AM : [ZWAVE-TX ZW012_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:10 AM : [D2D EVENT   ] Event [ZW012_1] [ERR] [0] uom=0 prec=-1
Fri 01/03/2020 10:06:10 AM : [     ZW012_1]      ERR   0
Fri 01/03/2020 10:06:10 AM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x33.03 SWITCH_COLOR
Fri 01/03/2020 10:06:10 AM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:10 AM : [ZWAVE-TX ZW012_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:10 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:06:10 AM : [D2D EVENT   ] Event [ZW012_1] [ERR] [1] uom=0 prec=-1
Fri 01/03/2020 10:06:10 AM : [     ZW012_1]      ERR   1
Fri 01/03/2020 10:06:10 AM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:06:10 AM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Fri 01/03/2020 10:06:11 AM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:11 AM : [ZWAVE-TX ZW012_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:16 AM : [D2D EVENT   ] Event [ZW012_1] [ERR] [0] uom=0 prec=-1
Fri 01/03/2020 10:06:16 AM : [     ZW012_1]      ERR   0
Fri 01/03/2020 10:06:16 AM : [ZW-TX-FAILED] enc=Fail uid=12.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:06:16 AM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Fri 01/03/2020 10:06:16 AM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:16 AM : [ZWAVE-TX ZW012_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0C
Fri 01/03/2020 10:06:16 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:06:16 AM : [D2D EVENT   ] Event [ZW012_1] [ERR] [1] uom=0 prec=-1
Fri 01/03/2020 10:06:16 AM : [     ZW012_1]      ERR   1
Fri 01/03/2020 10:06:16 AM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Fri 01/03/2020 10:06:16 AM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Fri 01/03/2020 10:06:21 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:06:21 AM : [D2D EVENT   ] Event [ZW013_1] [ERR] [1] uom=0 prec=-1
Fri 01/03/2020 10:06:21 AM : [     ZW013_1]      ERR   1
Fri 01/03/2020 10:06:21 AM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:06:21 AM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Fri 01/03/2020 10:06:22 AM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Fri 01/03/2020 10:06:22 AM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Fri 01/03/2020 10:06:22 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:06:22 AM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:06:22 AM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Fri 01/03/2020 10:06:23 AM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Fri 01/03/2020 10:06:23 AM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Fri 01/03/2020 10:06:27 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:06:27 AM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Fri 01/03/2020 10:06:27 AM : [ZWAVE-TX ZW014_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:06:28 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:06:28 AM : [ZWAVE-WAIT      ] Waiting 47 ticks for retry 1 of 2
Fri 01/03/2020 10:06:30 AM : [ZWAVE-TX ZW014_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:06:32 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:06:32 AM : [ZWAVE-WAIT      ] Waiting 45 ticks for retry 2 of 2
Fri 01/03/2020 10:06:34 AM : [ZWAVE-TX ZW014_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:06:35 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:06:35 AM : [D2D EVENT   ] Event [ZW014_1] [ERR] [1] uom=0 prec=-1
Fri 01/03/2020 10:06:35 AM : [     ZW014_1]      ERR   1
Fri 01/03/2020 10:06:35 AM : [ZW-TX-FAILED] 14.0/0x26.02
Fri 01/03/2020 10:06:35 AM : [ZWAVE-TX ZW014_001_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:06:40 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:06:40 AM : [ZWAVE-WAIT      ] Waiting 47 ticks for retry 1 of 2
Fri 01/03/2020 10:06:42 AM : [ZWAVE-TX ZW014_001_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:06:47 AM : [ZWAVE-WAIT      ] Waiting 20 ticks for retry 2 of 2
Fri 01/03/2020 10:06:48 AM : [ZWAVE-TX ZW014_001_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:06:53 AM : [D2D EVENT   ] Event [ZW014_1] [ERR] [0] uom=0 prec=-1
Fri 01/03/2020 10:06:53 AM : [     ZW014_1]      ERR   0
Fri 01/03/2020 10:06:53 AM : [ZW-TX-FAILED] 14.1/0x26.02
Fri 01/03/2020 10:06:53 AM : [ZWAVE-TX ZW014_002_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:06:53 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:06:53 AM : [ZWAVE-WAIT      ] Waiting 44 ticks for retry 1 of 2
Fri 01/03/2020 10:06:55 AM : [ZWAVE-TX ZW014_002_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:06:58 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:06:58 AM : [ZWAVE-WAIT      ] Waiting 43 ticks for retry 2 of 2
Fri 01/03/2020 10:07:00 AM : [ZWAVE-TX ZW014_002_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:00 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:07:00 AM : [D2D EVENT   ] Event [ZW014_1] [ERR] [1] uom=0 prec=-1
Fri 01/03/2020 10:07:00 AM : [     ZW014_1]      ERR   1
Fri 01/03/2020 10:07:00 AM : [ZW-TX-FAILED] 14.2/0x26.02
Fri 01/03/2020 10:07:01 AM : [ZWAVE-TX ZW014_003_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:05 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:07:05 AM : [ZWAVE-WAIT      ] Waiting 40 ticks for retry 1 of 2
Fri 01/03/2020 10:07:07 AM : [ZWAVE-TX ZW014_003_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:12 AM : [ZWAVE-WAIT      ] Waiting 24 ticks for retry 2 of 2
Fri 01/03/2020 10:07:14 AM : [ZWAVE-TX ZW014_003_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:19 AM : [D2D EVENT   ] Event [ZW014_1] [ERR] [0] uom=0 prec=-1
Fri 01/03/2020 10:07:19 AM : [     ZW014_1]      ERR   0
Fri 01/03/2020 10:07:19 AM : [ZW-TX-FAILED] 14.3/0x26.02
Fri 01/03/2020 10:07:19 AM : [ZWAVE-TX ZW014_004_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:19 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:07:19 AM : [ZWAVE-WAIT      ] Waiting 46 ticks for retry 1 of 2
Fri 01/03/2020 10:07:21 AM : [ZWAVE-TX ZW014_004_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:24 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:07:24 AM : [ZWAVE-WAIT      ] Waiting 44 ticks for retry 2 of 2
Fri 01/03/2020 10:07:26 AM : [ZWAVE-TX ZW014_004_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:26 AM : [ZWAVE-RX-ST     ] No Device Ack
Fri 01/03/2020 10:07:26 AM : [D2D EVENT   ] Event [ZW014_1] [ERR] [1] uom=0 prec=-1
Fri 01/03/2020 10:07:26 AM : [     ZW014_1]      ERR   1
Fri 01/03/2020 10:07:26 AM : [ZW-TX-FAILED] 14.4/0x26.02
Fri 01/03/2020 10:07:26 AM : [ZWAVE-TX ZW014_005_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:31 AM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Fri 01/03/2020 10:07:31 AM : [ZWAVE-WAIT      ] Waiting 43 ticks for retry 1 of 2
Fri 01/03/2020 10:07:33 AM : [ZWAVE-TX ZW014_005_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:38 AM : [ZWAVE-WAIT      ] Waiting 21 ticks for retry 2 of 2
Fri 01/03/2020 10:07:39 AM : [ZWAVE-TX ZW014_005_1] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0E
Fri 01/03/2020 10:07:44 AM : [D2D EVENT   ] Event [ZW014_1] [ERR] [0] uom=0 prec=-1
Fri 01/03/2020 10:07:44 AM : [     ZW014_1]      ERR   0
Fri 01/03/2020 10:07:44 AM : [ZW-TX-FAILED] 14.5/0x26.02
Fri 01/03/2020 10:07:49 AM : [        Time] 10:07:49 0(0)
Fri 01/03/2020 10:07:49 AM : [INST-TX-I1  ] 02 62 00 00 3A CF 14 00
Fri 01/03/2020 10:07:49 AM : [INST-ACK    ] 02 62 00.00.3A CF 14 00 06          LTOFF-F(00)
Next I'm going to pull the plug and see if a power cycle will revive my system. Any suggestions are welcomed :)
Nope, power cycle made no difference.
Running Zwave 4.55.00 bootloader 1.03 on a
(Oups, I see I never upgraded to version B. But still, it should still have been able to use Z-wave.)
Edited by MrWorf
Did the power cycle
Odd, I changed antenna from internal to external and now it's seeing nodes again.
Yes using the 16B console and firmware.  Rebooting did not change anything.  I clicked to clear the error log while the cursor was still rotating and the file menu appeared to save the log, and indeed the log was saved properly (with content back to October).  The log was not cleared despite having said yes to clearing it.   After the log was saved to a file  then perhaps  I was able to clear the log (when I tried to access the log after clearing it I get an error message  (first could not access some portal file and then "request failed", which is the error it gives now.  So I'll follow up later after it generates some content for the log (?).
I see the last time I tried to generate an error log was on 5.0.15A on October 11  so I don't know when this behavior started
I cannot figure out the install instructions from 4.7.3.
I have updated my Java, Cleared my Java Cache, Backed up my system. Downloaded
Quote
3.  Download firmware
  -  ISY 994i Series including Z-Wave support
As I use PLM.  I also just purchased the Z Wave HW Module and will install later.
Launched
Quote
  Note: If you have version 5.0.8 or lower installed on your ISY, then use this link instead:
  -  http://isy.universal-devices.com/994i/5.0.16/admin.jnlp
selected upgrade option then browsed to the "insteon_5.0.16B" zip file from the download firmware step.
After letting the files upload, I get "Upgrade Failed: Failed uploading file (reported written size is invalid)" and "The ISY was not upgraded"
***UPDATE*** 4-Jan 2020
I successfully upgraded.  I believe my problem was that I did not use the java parameter -Xmx512m
Edited by epete
Now it appears to be working normally (with an error log with only a couple of handfuls of lines)
Backup of 5.0.16B fails.  I used an old ISY for a new installation.  Factory reset the ISY and PLM, added new ISY devices, imported some net rules and imported some programs.  I get the following error and the backup quits.
ISY Backup Error.pdf
And now it happened again, all zwave devices are offline and my log is filled with:
Sun 01/05/2020 06:36:47 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Is my ZWave card fried?
Switching antennas worked earlier, but this is the result today:
Sun 01/05/2020 06:36:41 PM : [ZWAVE-WAKEUP  13.000] Query device ZW013_1
Sun 01/05/2020 06:36:41 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:36:42 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:36:47 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:36:48 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:36:49 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:36:53 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:36:53 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Sun 01/05/2020 06:36:54 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:36:55 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:00 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:37:00 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:01 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:06 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:37:06 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:37:06 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:07 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:12 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:37:12 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Sun 01/05/2020 06:37:13 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:14 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:18 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:37:18 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:19 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:24 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:37:24 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:37:25 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:26 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:31 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:37:31 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Sun 01/05/2020 06:37:31 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:32 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:37 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:37:37 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:38 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:43 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:37:43 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:37:43 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:44 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:49 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:37:49 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Sun 01/05/2020 06:37:49 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:50 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:37:55 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:38:03 PM : Setting Port 1 Serial RTS Off
Sun 01/05/2020 06:38:03 PM : Setting Port 1 Serial RTS On
Sun 01/05/2020 06:38:03 PM : [UZW-CMD 18      ] Set Active Antenna
Sun 01/05/2020 06:38:11 PM : [ZWAVE-WAKEUP  13.000] Query device ZW013_1
Sun 01/05/2020 06:38:11 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:14 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:14 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[87AF0F913BF8118C] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:38:14 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:38:15 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[87AF0F913BF8118C] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:38:19 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:38:19 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:38:20 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:20 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:20 PM : [ZWAVE-RX-ST     ] No Device Ack
Sun 01/05/2020 06:38:20 PM : [D2D EVENT   ] Event [ZW013_1] [ERR] [1] uom=0 prec=-1
Sun 01/05/2020 06:38:20 PM : [     ZW013_1]      ERR   1
Sun 01/05/2020 06:38:20 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:38:20 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Sun 01/05/2020 06:38:20 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[FA636A333B54FB8B] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:38:20 PM : [D2D EVENT   ] Event [ZW013_1] [ERR] [0] uom=0 prec=-1
Sun 01/05/2020 06:38:20 PM : [     ZW013_1]      ERR   0
Sun 01/05/2020 06:38:21 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:21 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:21 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[918E47AC4A5F1978] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:38:21 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:38:26 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:38:26 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:26 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:26 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[1EEA755DB947D363] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:38:27 PM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Sun 01/05/2020 06:38:27 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:38:27 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:38:27 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:27 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:27 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[115C5C8C2CCA1FE7] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:38:27 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:38:32 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:38:32 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Sun 01/05/2020 06:38:33 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:33 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:37 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:38:37 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:37 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:39 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[8B6D5342128BDB8E] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:38:39 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:38:43 PM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Sun 01/05/2020 06:38:43 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:38:43 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:38:44 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:44 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:49 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:38:49 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Sun 01/05/2020 06:38:49 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:49 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:38:50 PM : [ZWAVE-RX-ST     ] No Device Ack
Sun 01/05/2020 06:38:50 PM : [D2D EVENT   ] Event [ZW013_1] [ERR] [1] uom=0 prec=-1
Sun 01/05/2020 06:38:50 PM : [     ZW013_1]      ERR   1
Sun 01/05/2020 06:38:50 PM : [ZW-TX-FAILED] enc=Fail uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:38:51 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[F093AC75C69BCCB9] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:38:51 PM : [D2D EVENT   ] Event [ZW013_1] [ERR] [0] uom=0 prec=-1
Sun 01/05/2020 06:38:51 PM : [     ZW013_1]      ERR   0
Sun 01/05/2020 06:38:51 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[BA61263FEEE12DAE] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:03 PM : Setting Port 1 Serial RTS Off
Sun 01/05/2020 06:39:04 PM : Setting Port 1 Serial RTS On
Sun 01/05/2020 06:39:04 PM : [UZW-CMD 18      ] Set Active Antenna
Sun 01/05/2020 06:39:11 PM : [ZWAVE-WAKEUP  13.000] Query device ZW013_1
Sun 01/05/2020 06:39:11 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:14 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:14 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[87A238C6BC82FAB5] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:15 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[9521C4D81E74BD7E] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:19 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x26.02 SWITCH_MULTILEVEL
Sun 01/05/2020 06:39:19 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:39:19 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:19 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:20 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[083B3F4F072FDB89] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:20 PM : [ZWAVE-RX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:20 PM : [ZWAVE-TX        ] ...
Sun 01/05/2020 06:39:20 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:39:21 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:39:21 PM : [ZWAVE-RX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:21 PM : [ZWAVE-TX        ] ...
Sun 01/05/2020 06:39:21 PM : [ZWAVE-RD        ] [010A00130D03260363250074]              REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:22 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:22 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:22 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:39:22 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[2A247662C4987D75] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:22 PM : [ZWAVE-RX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:22 PM : [ZWAVE-TX        ] ...
Sun 01/05/2020 06:39:23 PM : [ZWAVE-RD        ] [010B00130D0433040200250011]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:23 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [03] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:23 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:24 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[939CA441840DA106] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:24 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[B5588FC2988D3A8C] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:29 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:39:29 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:39:29 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [03] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:29 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:29 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[9EDB1049CE9E1B91] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:29 PM : [ZWAVE-RX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:29 PM : [ZWAVE-TX        ] ...
Sun 01/05/2020 06:39:30 PM : [ZWAVE-RD        ] [010B00130D04330403FF2500F5]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:30 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [04] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:30 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:31 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[2813443B2EC61069] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:31 PM : [ZWAVE-RX ZW011_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x0B
Sun 01/05/2020 06:39:31 PM : [ZWAVE-TX        ] ...
Sun 01/05/2020 06:39:31 PM : [ZWAVE-RD        ] [010900130B0284072500B3]                REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:31 PM : [ZWAVE-WAKEUP  11] Awake with no pending work, putting back to sleep ZW011_1
Sun 01/05/2020 06:39:31 PM : [ZWAVE-RX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:31 PM : [ZWAVE-RD        ] [010B00130D0433040400250003]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:32 PM : [ZWAVE-TE        ] [84/08] Wakeup No More Information ACK,AUTO,EXPLORE To=0x0B
Sun 01/05/2020 06:39:32 PM : [ZWAVE-TX ZW011_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0B
Sun 01/05/2020 06:39:32 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:39:32 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[36479C7834AE0295] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:33 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[36479C7834AE0295] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:33 PM : [ZWAVE-RD        ] [010B00130D0433040400250005]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:33 PM : [ZWAVE-RD        ] [010B00130D0433040400250006]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:34 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[D7CE01975C836CF4] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:35 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[02C52BC263168B72] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:37 PM : [ZW-TX-FAILED] enc=Fail uid=11.0 cmd=0x84.08 WAKE_UP
Sun 01/05/2020 06:39:37 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:39:37 PM : [ZWAVE-TE        ] [26/02] Dimmer Switch Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:37 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:37 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[80AA81613C8A747B] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:37 PM : [ZWAVE-RX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:37 PM : [ZWAVE-TX        ] ...
Sun 01/05/2020 06:39:38 PM : [ZWAVE-RD        ] [010A00130D03260363250066]              REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:38 PM : [ZWAVE-RD        ] [010A00130D03260363250065]              REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:38 PM : [ZWAVE-RD        ] [010A00130D03260363250064]              REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:38 PM : [ZWAVE-TE        ] [84/08] Wakeup No More Information ACK,AUTO,EXPLORE To=0x0B
Sun 01/05/2020 06:39:38 PM : [ZWAVE-TX ZW011_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0B
Sun 01/05/2020 06:39:38 PM : [ZWAVE-RX ZW011_1] [98/80] Security Nonce Report - nonce=[669D1DDB18DCEBFD] ACK,AUTO,EXPLORE From=0x0B
Sun 01/05/2020 06:39:38 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [02] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:38 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:41 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[E44CECAEA87C6597] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:41 PM : [ZWAVE-RX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:41 PM : [ZWAVE-TX        ] ...
Sun 01/05/2020 06:39:41 PM : [ZWAVE-RD        ] [010B00130D043304020025000B]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:41 PM : [ZWAVE-RD        ] [010B00130D0433040200250008]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:42 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [03] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:42 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:42 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:39:42 PM : [ZWAVE-RD        ] [010B00130D0433040200250006]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:42 PM : [ZWAVE-RD        ] [010B00130D0433040200250007]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:42 PM : [ZWAVE-RD        ] [010B00130D0433040200250004]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:42 PM : [ZWAVE-RD        ] [010B00130D0433040200250005]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:43 PM : [ZWAVE-RD        ] [010B00130D0433040200250002]            REQ ZW_SEND_DATA
Sun 01/05/2020 06:39:45 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[814ED21B0952C5E4] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:45 PM : [ZWAVE-RX-ST     ] No Device Ack, trying again
Sun 01/05/2020 06:39:45 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:39:45 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 1 of 2
Sun 01/05/2020 06:39:45 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[241DC9FB866D6690] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:45 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [03] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:45 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:45 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:39:46 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[241DC9FB866D6690] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:46 PM : [ZWAVE-RX-ST     ] Send queue full
Sun 01/05/2020 06:39:47 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[241DC9FB866D6690] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:51 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x33.03 SWITCH_COLOR
Sun 01/05/2020 06:39:51 PM : [ZWAVE-TX-E      ] ZWAVE-WAIT Waiting for retry 2 of 2
Sun 01/05/2020 06:39:51 PM : [ZWAVE-TE        ] [33/03] CC=0x33 cmd=0x03 [03] ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:51 PM : [ZWAVE-TX ZW013_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE To=0x0D
Sun 01/05/2020 06:39:52 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[CB0E930FB01814D4] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:52 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[9304806E538ABBD6] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:53 PM : [ZWAVE-RX ZW013_1] [98/80] Security Nonce Report - nonce=[9304806E538ABBD6] ACK,AUTO,EXPLORE From=0x0D
Sun 01/05/2020 06:39:57 PM : [ZW-TX-FAILED] enc=Ok uid=13.0 cmd=0x33.03 SWITCH_COLOR
What happens if you disable switch 13 and then retry
1 hour ago, MrWorf said:
ZW013_1
That device is trying to do a security handshake and failing... remove power from it like @lilyoyo1recommended and see what happens.
Right click on the device in the admin console there is also an option to disable the device
i lost heat/cool state for my insteon thermostats  with the latest revision 5.0.16b.  i don't remember if it worked in 16.
is there anything i can do or is it lost going to the new revisions?
thanks
Thank you!  I reverted back to 5.0.16 and all seems to work fine now.
thanks
On my 2441THv.10 thermostat, Heat and Cool states still work under 16b.  Just verified.
Sorry, I should have been more clear, that was just an excerpt of the log, ALL zwave devices show the same error, no zwave device is able to communicate until I do the following:
  1. Reboot ISY
  2. Change antenna
Then it works for about 8-24hrs and then it fail again. (for some reason quoting didn't happen @lilyoyo1 @simplextech)
Edited by MrWorf
I am assuming that Version 5.0.16 is still in Beta. I am currently using 4.7.3 and the system has not informed a new updated firmware is available. Patiently waiting. Really would like to use the Motion Sensor 2 to name just one feature I am looking forward to.
Thanks.
Thanks.
5.0.16B fully supports the motion sensor II.  However there are a few minor bugs, one affecting the open/close sensor. All in all it's a stable release. Be sure to follow the update instructions.
actually both houses are working for the state.  one was still 5.0.16 and the one working is B.  i upgraded to B on the other house and the state works.
probably something with insteon versions, i had to replace a couple over the years.
