YoLink NS installation issues
I am running V0.8.50 and am seeing some installation issues with trying to upgrade to the latest version (0.8.88) of the YoLink node server.  If I restart the node server, it briefly reflects that the version was updated to V0.8.88, then a few seconds later it displays V0.8.50 again.
I think this issue has been there for a little while, but I was able to previously get around this by deleting the old Node Server and doing a clean install of the latest version, but that no longer seems to work.  If I try to delete the existing Node Server I get an error "Failed to remove Node Server YoLink from slot 60: Cannot read properties of null (reading 'filename')".
Any suggestion on how to install the latest version?
Edited by dwengrovitz
updated formating of text slightly
Solved by Panda88
I tried upgrading via PG3x (by either restarting the node server, or attempting to delete and reinstall).  I wasn't aware there was a way to upgrade node serves from within the AC.
Ahh, got it.  I updated pg3x to 3.1.24 and the issue with not being able to update the node server via a restart was still there, but I was able to successfully delete and reinstall the node server to get the latest version.  Thanks very much for the assistance!
