POE power?
Just curious, has anyone tried powering an eisy using a POE splitter?
Bruce.
Solved by elvisimprsntr
Bruce.
UDI hasn't said anything about eisy being capable of being powered by poe
DISCLAIMER
Use at your own peril.  If you are considering installing in a cabinet/junction box, make sure there is adequate ventilation.
Power Specs for PoE
https://en.wikipedia.org/wiki/Power_over_Ethernet
Power Specs for MeLE Quieter3Q (12v x 2a = 24w)
https://store.mele.cn/products/mele-fanless-mini-pc-quieter3q-n5105-windows-11-pro-micro-computer-8gb-ddr4-256gb-rom-small-desktop-computers-for-office-home-dual-hdmi-4k-60hz-bt5-2-wi-fi-6-usb3-0-ethernet-port-vesa-mount?variant=41899440144562
PoE to USB-C Power Adapter
Of course you will need an adequately sized separate PoE++ injector or PoE++ Ethernet switch.
https://www.amazon.com/Procet-Gigabit-Splitter-IEEE802-3at-PT-PTC-at/dp/B07X46S3GD/
Edited by elvisimprsntr
Thanks for the info! I was missing the specs on the input power for the eisy.
If and when I try this, I’ll report results back. I just happen to be putting my eisy in a place with plenty of POE ports (need to double check which variant of POE) but not a lot of electrical outlets. It’s not a requirement for me but it’d make some things easier.
Bruce.
2 hours ago, Brian H said:
Verify the POE source voltage.
The eisy is strictly 12V DC from what I saw on its sales page.
Alas this idea isn't going to work for me, it turns out that 24W is beyond the power budget of a single switch port (UniFi US-8 60W). Oh well, thanks to all for the info!
Bruce.
