Elk Node Server Log
Hi @Jimbo.Automates,
I was checking PG3 today and noticed some warnings repeating in the log. I checked my Elk system and the Elk log and all was fine.
Not sure what any of the following means, do I need to do something:
2023-04-14 12:46:17,360 ELK-2691   udi_interface      WARNING  Controller:init_isy: pyisy_version=2.1.6
2023-04-14 12:46:17,361 ELK-2691   udi_interface      INFO     Controller:init_isy: ELK Controller: got isy=<udi_interface.isy.ISY object at 0x803cd3100> pyisy=<pyisy.isy.ISY object at 0x803ceea00> pyisy.connected=True
2023-04-14 12:46:17,362 ELK-2691   udi_interface      WARNING  Controller:sync_complete: ELK Controller: No node address or name match for 'Outdoor Pole_Wa'
2023-04-14 12:46:17,363 ELK-2691   elkm1_lib.notify   ERROR    notify:notify: 'bool' object has no attribute 'address'
Traceback (most recent call last):
  File "/var/polyglot/pg3/ns/000db952c01c_2/elkm1_lib/notify.py", line 39, in notify
    observer(**notify_parameters)
  File "/var/polyglot/pg3/ns/000db952c01c_2/nodes/Controller.py", line 538, in sync_complete
    if node.address.endswith('_'+default_address):
AttributeError: 'bool' object has no attribute 'address'
2023-04-14 12:46:37,628 ELK-2691   udi_interface      INFO     Controller:callback: ELK Controller: element=0 'ElkM1' real_time_clock:3146126140423110 elkm1_version:5.2.10 xep_version:2.0.34 remote_programming_status:ElkRPStatus.DISCONNECTED system_trouble_status: temperature_units:F user_code_length:4 type=<class 'elkm1_lib.panel.Panel'> cs={'real_time_clock': '3146126140423110'}
2023-04-14 12:46:37,629 ELK-2691   udi_interface      INFO     Controller:callback: real_time_clock=3146126140423110
2023-04-14 12:46:38,236 Thread-6196 udi_interface      WARNING  Controller:handler_poll: waiting for sync and node initialization to complete
Edited by Jimbo.Automates
1 hour ago, Jimbo.Automates said:
Thanks, I'll take a look.  BTW, when posting Log, please enclose it in Code using the <> in the editor.
Edit: I fixed your post for you :)
Thank you, I completely forgot about that, sorry.
Are you running ELK NS 3.7.0 ?  It doesn't look like it based on the log provided.
When I was there this morning, there was no update message. I just checked again and there was still no update message. I went to purchases and did a reinstall and now I am on 3.7.0.
Here is what I get in the log now:
2023-04-14 18:05:02,780 Command    udi_interface      INFO     Area:cmd_display_message: display_message(1, False, 0, "Temp 76.14F", "Hum 35.08%")
2023-04-14 18:05:17,224 ELK-7665   udi_interface      INFO     Controller:callback: ELK Controller: element=0 'ElkM1' real_time_clock:1005186140423110 elkm1_version:5.2.10 xep_version:2.0.34 remote_programming_status:0 system_trouble_status: temperature_units:F user_code_length:4 type=<class 'elkm1_lib.panel.Panel'> cs={'real_time_clock': '1005186140423110'}
2023-04-14 18:05:17,225 ELK-7665   udi_interface      INFO     Controller:callback: real_time_clock=1005186140423110
2023-04-14 18:05:47,243 ELK-7665   udi_interface      INFO     Controller:callback: ELK Controller: element=0 'ElkM1' real_time_clock:4005186140423110 elkm1_version:5.2.10 xep_version:2.0.34 remote_programming_status:0 system_trouble_status: temperature_units:F user_code_length:4 type=<class 'elkm1_lib.panel.Panel'> cs={'real_time_clock': '4005186140423110'}
2023-04-14 18:05:47,244 ELK-7665   udi_interface      INFO     Controller:callback: real_time_clock=4005186140423110
2023-04-14 18:06:17,262 ELK-7665   udi_interface      INFO     Controller:callback: ELK Controller: element=0 'ElkM1' real_time_clock:1006186140423110 elkm1_version:5.2.10 xep_version:2.0.34 remote_programming_status:0 system_trouble_status: temperature_units:F user_code_length:4 type=<class 'elkm1_lib.panel.Panel'> cs={'real_time_clock': '1006186140423110'}
2023-04-14 18:06:17,264 ELK-7665   udi_interface      INFO     Controller:callback: real_time_clock=1006186140423110
2023-04-14 18:06:47,281 ELK-7665   udi_interface      INFO     Controller:callback: ELK Controller: element=0 'ElkM1' real_time_clock:4006186140423110 elkm1_version:5.2.10 xep_version:2.0.34 remote_programming_status:0 system_trouble_status: temperature_units:F user_code_length:4 type=<class 'elkm1_lib.panel.Panel'> cs={'real_time_clock': '4006186140423110'}
2023-04-14 18:06:47,282 ELK-7665   udi_interface      INFO     Controller:callback: real_time_clock=4006186140423110
2023-04-14 18:06:55,594 MQTT       udi_interface.interface INFO     interface:_message: Successfully set controller :: GV1 to 1 UOM 25
2023-04-14 18:07:17,290 ELK-7665   udi_interface      INFO     Controller:callback: ELK Controller: element=0 'ElkM1' real_time_clock:0907186140423110 elkm1_version:5.2.10 xep_version:2.0.34 remote_programming_status:0 system_trouble_status: temperature_units:F user_code_length:4 type=<class 'elkm1_lib.panel.Panel'> cs={'real_time_clock': '0907186140423110'}
2023-04-14 18:07:17,292 ELK-7665   udi_interface      INFO     Controller:callback: real_time_clock=0907186140423110
