Jimbo.Automates Posted May 4, 2023 Posted May 4, 2023 I'm adding a mini split to a small garage and was won if anyone has a recom for one that could be monitored and controlled by ISY? Or one that has an API that I can write a node server for? Sent from my Pixel 6 Pro using Tapatalk
kzboray Posted May 4, 2023 Posted May 4, 2023 Jimbo, I'm not sure which model you are installing, but these appear to still be available and will handle up to 30amps.Insteon Heavy Duty Load Controller
Jimbo.Automates Posted May 4, 2023 Author Posted May 4, 2023 Jimbo, I'm not sure which model you are installing, but these appear to still be available and will handle up to 30amps.Insteon Heavy Duty Load ControllerThanks, I actually have a Zwave 30 amp that was on my hot water tank which I replaced with a tankless, but I was more looking for one to monitor running status and adjust temp settings from ISY.Sent from my Pixel 6 Pro using Tapatalk
Jimbo.Automates Posted May 4, 2023 Author Posted May 4, 2023 35 minutes ago, kzboray said: Jimbo, How about this? Mini Split RPi Controller Wow, that's great, but a lot of time which I don't have much to spare lately, but will keep it in mind. Really surprising none of them seem to have Z-Wave or allow using a smart thermostat like Ecobee... A couple do have remote access using closed API. Might just have to use a Sensibo which is only one-way communication...
tlightne Posted May 4, 2023 Posted May 4, 2023 How about the Bond Bridge??? Most Mini splits have a remote...
Jimbo.Automates Posted May 4, 2023 Author Posted May 4, 2023 How about the Bond Bridge??? Most Mini splits have a remote...Yes it's an option, but still only one way communication like sensibo.Sent from my Pixel 6 Pro using Tapatalk
glarsen Posted May 4, 2023 Posted May 4, 2023 I have a Daikin system with an Intesis interface which has a node server in the store that gives you a reasonable level of control. 1
DennisC Posted May 5, 2023 Posted May 5, 2023 Haven't used it but I wonder if this would work: https://youhomeautomation.io/smart-climate-control/hvac-automation-controller/remotec-z-wave-a-c-controller/ 1
