Ring 1.1.0 is now available
bmercier
7 minutes ago, bmercier said:
FYI, Ring 1.1.0 is now available.
New feature: Add support for shared devices.
To support shared devices, you need to add a custom param "shared" with a value of "true" (without the double quotes)
How do I update to 1.1.0? Still showing 1.0.4 Beta
Link to comment
7 minutes ago, TUhl01 said:
Where is "Update" found?
I see 1.0.5 in Prod store, I just deleted 1.0.4 and installed (not re-install) into same node slot and it ran perfectly at 1.0.5
I didn't see Update option either but above process worked great
Edited by JBlake01
Link to comment
8 minutes ago, bmercier said:
I guess the Update button does not exists when the nodeserver is installed from the beta store.
You should reinstall from the production store. There is a trial available.
I made my purchase from the non-production store last week.  I just deleted that version and reinstalled from the production store.  All is good except I am back on a trial.  How do I bypass purchasing again to make permanent?
Link to comment
Go to Purchases -> Re-Install -> Update
Link to comment
In latest pg3 or pg3x you have to RESTART the nodeserver.
The authenticate you see in the picture will change to update.
then click update and a dialog will come up and click update again.
This is for ALL nodeservers
Link to comment
You can also do what @JBlake01said to do in previous post.  Basically the same thing since that is where the update button takes you.  But I always do my method.
Link to comment
      36.5k
      367.7k
