Does this work with Zigbee2MQTT?
I successfully got it talking to MQTT server on my Home Assistant. However, not sure how to get it to control Zigbee devices over zigbee2mqtt
I added a switch node based on example and I see it added the cmnd topic in there and, added a device/node in IoX. I could see it turning on/off using MQTT Explorer when I pressed the buttons in IoX. However, this seems to be instructions for tasmota devices which use cmnd topic. I wonder if it can control  zigbee2mqtt? I messed around a bit and no luck. Wondering if anyone has tried this, or is it even possible? This would be a way to get Zigbee devices into IoX by setting up zigbee2mqtt and a USB coordinator on another server.
I also noticed that when I deleted my test device in MQTT nodeserver, it did not delete it in IoX.
