How to turn on wifi after Eisy setup on ethernet?
TheA2Z
Wi-fi should automatically be off if the wired connection is made.  I don't think there are any setting adjustments needed.
@Geddy Thanks for quick response.
Let me clarify.  I am using ethernet now.  I never setup wifi when I installed Eisy.  I want to switch to using Wifi and not ethernet.
How can I do that?
Sorry, misread first post. Quick question first, why change to wifi? Are you moving it to somewhere that you cannot connect with a wire? I think it works fine both ways, but just seems more reliable to be wired connection. (IMO)
I think you will need to use UD Mobile to set up the wifi, but I’ve never gone from wired to wireless setting so don't know all the steps.
Try with UD mobile and review the wiki user guide
https://wiki.universal-devices.com/index.php?title=Eisy:User_Guide#Go_to_WIFI_Setup_or_Leave_WIFI_Setup_mode
@Geddy  Have been running ISY now Eisy via ethernet with powerline adapters.  Recently been getting loss of connection to ISY and PG3.  Not sure if it is powerline or something else.  Wanted to try WIFI before running hardware from server closet.
Ill check out that process you sent.
btw I see we are both in the Atlanta area.  Up in East Cobb.  How bout you?
Tried disconnecting the ethernet, then using UD mobile to connect to wifi.  Scanned code on bottom of EISY.  Selected my wifi, but I could not get it to connect to the eisy wifi connection.  UD mobile would just spin.
I have android Samsung S22.  it said it would ask for permission to connect to wifi but never came up.
Replicated an issue which may be related. Some Android devices or versions do not timeout when OS does not find WiFi Access Point, added to issues
Some common causes are listed in troubleshooting
https://wiki.universal-devices.com/index.php?title=UD_Mobile#Troubleshooting
  • Like 1
      38k
      379.4k
