I added the Leviton Smart Plug to my ISY.  Everything works perfectly except when I manually activate the smart plug, its status is not reflected in the ISY without querying the smart plug.  The event log shows it is sending communications to the ISY when I manually activate the switch, but no change in ISY status.
@dougos2 Could you add some additional system details to try to help?
  • What's your ISY994 Firmware?
  • What is your UI for Admin Console (Help -> About)
  • What series Z-Wave do you have? (Use this post to help determine your series controller)
Do you have any other Z-Wave devices that report status correctly? I'm not familiar with the smart plug, but it's possible it is a newer 500 or 700 series device that isn't correctly sending information to the ISY994 z-wave module you have.  Perhaps others with more z-wave experience can chime in, but additional information on your setup could be helpful.
With you using the ISY, I believe that you must be on the latest firmware and have to query your devices since leviton uses hail vs sending status automatically like other modern zwave devices do.
  • Thanks 1
@dougos2
Looks like might be a "known" issue with this brand/manufacturer. Here are a couple of old posts to review:
PS: Since these posts are archived the only way to find them is with Google Site Search. These don't show up when searching via the forums search tool.
