New eero router and now I can't login to Polyglot v3
Go to solution Solved by Techman,
I need some new ideas.  My old ones haven't worked.  I replaced my router with a eero mesh system.  My eisy has an IP reservation and I have no problems launching into it.  I can access the ISY portal without issues.  When I try to go into the Polyglot v3 from either the launcher or from the Administrative Console, the logon screen comes up, I enter my credentials, press the login button and nothing happens.  I have tried the Incognito mode on Chrome and tried using Microsoft Edge without luck.
Given that when I was using my old router there were no problems, I am wondering what is different with the eero router. Maybe the router isn't the problem.  I am open to anything.  I am probably just overlooked something.
Any suggestions?
Thanks.
RK
Yes, I have access to the devices and programs.  The programs are running as expected.  I rebooted the eisy and there was no change in the Polyglot login.  Press the button and nothing happens.  After reboot I confirmed that the devices are working normally, except for the KASA devices.  I can turn bulbs on and off, but the information in the administrative console is empty.
I truly appreciate the help and ideas.
RK
I pulled the power and verified that I am 5.6 on both the UI and the eisy.  I can now get into the Polyglot!
Thank you for your help.  I will add that to my bag of tricks.
RK
RK
It's a documented issue, they're working on it. It should be fixed in the next update.
  • Thanks 1
As I started working with the Polyglot this afternoon, I noticed that my KASA node server was showing the IoX as disconnected.  I have tried logging off and on, rebooting the eisy, rebooting the eisy with the power cord and numerous other groupings, but it is still not connected.  Am I missing something else for my bag of tricks and tips?
Thanks, RK
Thanks, RK
Try doing an "update packages" on the eisy. Current IoX firmware is 5.6.2, Current PG3 is 3.1.33
For some reason, I have not been able to get the 'update packages' to update anything.  I have tried repeatedly with both the reboot button and the power pulled.  I am tempted to restore an earlier configuration and see if that will allow me to update.
Do you have an other suggestions?
49 minutes ago, RKinOhio said:
Thanks, Dennis.   I tried the update and I am still at 5.6.0.  Any other thoughts?
Randy
Did you follow Michel's instructions about upgrading after a failure in his post?
If you haven't seen it, he said if you have a failed update, you need to reboot, then upgrade packages, and then a second reboot.
Have you tried this?
Just saw your note.  I was getting ready to send you an update.  I took a tip from Techman (Michael?) and powered the eisy off, then restarted.  I am now running 5.6.2.
Thanks to you both!
RK
