No Zigbee Tab
Updated to firmware 5.6.3 and it showns no Zigbee tab.  I have rebooted eisy and tried to reload firmware again, still no Zigbee tab at top.
comments?
On the Configuration/System tab you need to check the box to enable Zigbee Support then press the Save button followed by the Restart Iox button.
I performed the EISY upgrade (one push of front button), waited about 5 min, rebooted EISY (5 pushes of front button), waited a couple min while I cleared my java cache.
Ran "start.jnlp", logged into Admin LAN console, checked the Zigbee box, Saved the change, restarted IoX, and then logged back in - Zigbee tab was in the top menu (even without plugging in ZMatter dongle).
If you don't clear the java cache after the upgrade, you might get a message about mismatched SW and FW due to the upgrade (at least I did).
Edited by f11
