Camera live view is intermittent
I tried out the new camera feature, thanks for another great addition to UD Mobile!!
I have an EZVIZ camera and set up the rtsp stream.  It works intermittently.  When it doesn't work it comes up as a black screen or it says stopped (see attached).  VLC brings it up every time using the same url .
To close this out, there is an issue UD has identified.  Until they can fix it there is an easy work around.  Simply choose another tab, then return to the tab with the camera and it will load properly.
Thanks @Javi!
