Posted August 15, 20232 yr After updating PG3x to v3.2.1 and reinstalling all of the node servers, I noticed there was an update to Elk v3.8.0. After doing the upgrade, I noticed the version # on the Elk node server page was v0.0.0. I re-did the upgrade with the same result. I tried to sop and restart the node server with no change.
August 15, 20232 yr That's odd. @bmercier any idea why it would show that? With this release I removed the old server.json so it should get the version the new way now.
August 15, 20232 yr That's odd. @bmercier any idea why it would show that? With this release I removed the old server.json so it should get the version the new way now.No I’m not sure why. I also don’t use server.json for Ring, and it works well. Does the log tells us anything?Sent from my iPhone using Tapatalk
August 15, 20232 yr 13 minutes ago, bmercier said: No I’m not sure why. I also don’t use server.json for Ring, and it works well. Does the log tells us anything? Not sure, I was going to test on mine, but just noticed PG3 isn't telling me an upgrade is available? I'm on 3.7 and 3.8 is out?
August 15, 20232 yr I manually did a sync purchases, then it showed the update. Now I have the 0.0.0 as well and log says: 2023-08-15 13:54:43,570 MainThread udi_interface.interface WARNING interface:_get_server_data: get_server_data: failed to read file server.json: [Errno 2] No such file or directory: 'server.json'
August 15, 20232 yr Author 1 hour ago, Jimbo.Automates said: Version 3.8.1 released with the fix. I completed the upgrade and it fixed the version number issue. After about 5 minutes of uptime, I checked the node server in the admin console and it was showing disconnected. I had to restart the Elk node server and no all seems fine. Thank you.
August 16, 20232 yr 3 hours ago, Jimbo.Automates said: I know why now, I will fix in next release. What was the problem and how did you fix it?
August 16, 20232 yr What was the problem and how did you fix it?When removing the legacy server.json you must pass the version to the interface start call. I knew that but forgot.https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/commit/4d3299aac70944c2548ef2a4107bdb74253e1dc3Sent from my Pixel 6 Pro using Tapatalk
