Support thread for: PG3x v3.2.3 (August 29th, 2023)
3 hours ago, bgrubb1 said:
I tried to purchase the free wemo NS  red error box saying failed and returned me to purchase page
@bgrubb1, I can reproduce the problem.
You can expect a fix in 3.2.4 this week.
  • Thanks 1
On 9/3/2023 at 4:32 PM, Michel Kohanim said:
@everyone,
Apologies for the weekend fire. This is now fixed in udx-3.5.1_4. In short, there were some python packages that depended on the newer version of pyopenssl. Now, udx makes sure those packages are installed.
1. Admin Console | Configuration tab | Upgrade Packages, or
2. Click on the power button once
3. Wait for the reboot notification in the Admin Console
- Admin Console | Configuration tab | Reboot, or
2. Click the power button 5 times
Tried this to no avail.  Clicked update packes and got a beep followed by 5 beeps.  Then manually rebooted.  Can't tell if it did anything though and almost all my NS's are still disconnected.
Try to go to:   https://##.##.##.##:8443/WEB/sysconfig.txt
(replacing the #s with your Polisy IP address.)
Then search for "UDX". It should read:
udx-3.5.1_4                    Polisy/eisy Admin Service
When you said you "manually rebooted" did you pull power to the Polisy or use the "Reboot" button in Admin Console?
Thanks Geddy.  I will do that when I get home.  Since posting, I did pull the plug.  In fact I went though several 'Update Pakages' then pull the plug after completion cycles.  So here's where I'm at.  It looks like PG3x did finally install but when I go to the PG3x webpage, it says no IOX devices can be found.  Add one!  Very strange as I have no issue accessing the admin console.  So that's where I'm now stuck.
A couple of things to check:
In PG3x, go to IoX Configuration menu, at the top, you should see your ISY uuid & a check mark. If you don't try clicking Auto Discover IoX's. If that doesn't work, you can add your system manually.
IP should be 127.0.0.1 & port 8080, then add user name & password. Highlight HTTP at the bottom & Save.
On 12/2/2022 at 6:37 PM, bpwwer said:
No, I'll clean up the change and push it to the production store.
i am having the same issue.  I followed the guidance in this thread and still getting the error.    I am finding the UID/isy and verified i am using udx-3.5.1_4.
Thanks but no luck.  Trying to add the IoX manually did not appear to do anything.  As in nothing happened at all when I clicked save:
Look down at the bottom of your screenshot and you will see PG3x Restart Required.
You need to reboot Polisy.
I know. I’ve done that maybe 10 times. It doesn’t work.
Please open a ticket.
When not detecting local IoX, it's a symptom of a bigger problem with either the UDX or ISY service.
      38k
      379k
