AT&T to end email-to-text ×
Opening Admin Console on a 99i
apostolakisl
Posted (edited)
I have an old 99i that I am using as the IR receiver for my polisy since polisy has no IR receiver on it.  Last login was about a year ago and was done by going to the following url:
http://xxx.xxx.xxx.xxx/99i/3.3.10/admin.jnlp
This downloaded admin.jnlp   I could run admin.jnlp and it opened the java console.  Now, I get the following security error:
I can not figure how to get around this.  I tried shutting down checking certificates in the advanced tab of java but it did not work.
Edited by apostolakisl
Posted (edited)
32 minutes ago, MrBill said:
What does the "more information" button reveal? I expect the certificate expired.
According to this, it expired a decade ago, but I just logged in about a year ago.
not an expert here but suggestions, is the java control panel set to high or very high?  If very high then try high.  Looks like you can create an exception list too, but I have absolutely no idea what needs to go there..
@MrBill It is set to just high, not very high.  I tried putting the url of my isy in the exception list but that did not work.  I also tried changing around some of the settings under the advanced tab but again no luck.
I don't know exactly how this works.  But clearly the admin.jnlp file is downloaded from the isy itself when you go to http://my.isy.ip/99i/3.3.10/admin.jnlp  But then when you run that admin.jnlp file, not sure if it is loading java console from the isy or from some website.
I have seen a similar security message when trying to access an old ISY99i.
My Java Security display use to have a third security choice that relaxed the security setting to below the High choice. Now gone.
2 hours ago, larryllix said:
I thought only https websites required certificates??
it isn't a security issue with the web browser.  Downloading the admin.jnlp file goes fine.  It is when you run that file that java gets involved and java blocks it.
Any ideas?  Perhaps I could install an old version of java?  Do you know how old you have to go to still have that option?  I can tell you that I opened my 99i admin console about 18 months ago and didn't have to do anything at all.  Presumably the certificate was still valid?
I tried the lox finder on an isy99i and it also showed a ISY994i. Nothing happen for me also to find an Administrative Console.
I thought you needed an older finder for an ISY99i. It had the last 3.3.10 released for that model.
Try Java Control Panel > Advanced, set Perform signed code certificate revocation checks on  to Do not check.
Posted (edited)
I had already tried that.  But just in case, I tried again, and still no go.  I also tried setting the other two items that are (not recommended), in other words, all three no recommended items were checked and it still doesn't work.
Bumping this back up hoping maybe someone has an answer for me.  I was using the 99ir with my Harmony remote to receive the ir commands and then relay the event to my Polisy via Rest commands.  This just randomly stopped working, and I can't figure out where the disconnect is whiteout logging into ISY99ir
      37.7k
      376.9k
