AT&T to end email-to-text ×
Phantom Device
mitch236
I would love to have the ability to create a phantom device within the ISY. The device wouldn't really exist on the network (there's no hardware) but it could be used to define the state a program is in.
An example would be:
From 11:20:00AM
To 3:20:00PM (same day)
And Status 'Outdoor / Pool / Phantom Device' is On
Set 'Outdoor / Pool / Pool Pump' On
Set 'Outdoor / Pool / Pool Pump' Off
The reason for the phantom device is that I was trying to write a program that uses a device from the Then statement that was used as a condition of the If portion. The problem is the program would abort as soon as the status of the device changed and the If statement became false.
Hi mitch236,
You can use the status of a program as a binary variable (true/false) which would have the same effect as what you have outlined.
Once we have variable support, then most of these issues will be solved.
