Using with ud mobile
Hi
on ud mobile I want to create an menu (as an example)
what do I do.  I need to be able to select Apple TV and then menu on the press of the up arrow.
Solved by DennisC
Just to add I know I can create a command widget and the the user can click on the three dots and pick the command.  I want to preselect the command so that each option is a separate widget
When creating a tile or widget of the command type, you can select and set display status and the command to run.
At the bottom of the screen, select add, followed by the node. You then select from available run commands.
Does this do what you want?
