Difference Between Control and Status
So this program is not running (ie not turning off the switch after five minutes).
Should I be using Control instead of Status in the "If" line?  If so, why?  I never seem to get the difference between the two.
Bathroom Fan Copy
        Status  'Second Floor / Bathroom Fan' is On
        Wait  5 minutes
        Set 'Second Floor / Bathroom Fan' Off
Thanks very much.
Solved by Techman
This is how it should be written..  An else statement will only run if the IF statement is false.
IF
   Wait 5 minutes
"Control" monitors signals that operate a device.
"Status" monitor the change of status inside a device.
If some devices sends ON...ON...ON... "Control" programs will trigger three times. "Status" programs will only trigger once if the device changes to ON.
This is classically used for Switchlinc switches. The light may already be on when somebody taps the up toggle switch. Status cannot detect that. Control could detect it and scroll the brightness level through 3 to 100 brightness levels on each tap.
Thanks for the reply and the above now makes complete sense.  Thank-you.
Thank-you  larryllix.  Very helpful.
