Elk Controller Main Page seems incorrect
I was investigating using some of the values on this page.
But see a number of things that make no sense.  First off, my Elk is connected to ISY and correctly tracking the armed status and the zones and all the usual stuff.  But on this page, it shows the node server as "disconnected", but it clearly is connected.  It also says "false" on a bunch of things like having an output and input expander (which I have several of) and ethernet as "false" despite it clearly being connected.  Also "dislplay message in keypad" is false, yet I have messages being displayed via ISY and this node server.
3 minutes ago, Jimbo.Automates said:
The disconnected is a bug in PG3, I'll release a workaround when I have time. All the false are System Trouble Status reported by ELK, so all false's are good they're documented in the readme. https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK
Sent from my Pixel 8 Pro using Tapatalk
May I suggest then renaming some of them.  For example, instead of "zone expander", name it "zone expander trouble".  It would make it butt obvious then.  Cause. . .  who has time to read the instructions?
