AT&T to end email-to-text ×
How To Mark a Post As A Solution
mbking
Thought this would be obvious, but I can't figure out how to mark a post as the "solution" to an issue I add to the forum.  Can someone post the steps?
@mbking Do you have a thread that needs to have an answer indicated? Most forums have the option to have that on, and some allow the OP to mark the answer while others require at least moderator status. Some areas (like this one) do not have that "answer" option turned on.
Just post a link or send me a PM (and indicate the post that should be the answer) and I'll take a look.
Thanks @lilyoyo1 for the heads up.
@Geddy, thanks for the reply.  The topic I was referring to is:
However, Javi recently marked his reply as the "Solution" which is what I thought I needed to do.  Your explanation cleared this up.  Thanks.
  • Thanks 1
