Kentinada Posted November 29, 2023 Posted November 29, 2023 I have a program that ran this morning to turn off outdoor Christmas lights after sunrise. The program ran. The Main page shows the devices are OFF (attached screenshot) but the devices are both still ON. I have a new Eisy coming and I'm not sure it will be better at controlling these are not. The lights are plugged into INSTEON outdoor outlets. Ideas?
mmb Posted November 29, 2023 Posted November 29, 2023 On 11/29/2023 at 1:55 PM, Kentinada said: The Main page shows the devices are OFF (attached screenshot) but the devices are both still ON. Expand Anything in the Error Log?
Kentinada Posted November 29, 2023 Author Posted November 29, 2023 Nothing at the time of the program running. Attaching the event viewer contents for 7:53a the time the program ran. The 2 INSTEON addresses are the addresses of the outdoor plugs. Not sure if this helps or not.
gregkinney Posted November 29, 2023 Posted November 29, 2023 @Kentinada What happens if you query the devices?
Kentinada Posted November 29, 2023 Author Posted November 29, 2023 I had the Scene selected and pressed the Query button. Here is the event viewer info attached. Does this help?
gregkinney Posted November 29, 2023 Posted November 29, 2023 Just go to each device and query it in the admin console and see if the status changes from OFF to ON (if they are indeed still on).
Kentinada Posted November 29, 2023 Author Posted November 29, 2023 When I set the scene to On and the lights don't really go on, when I query the device, it says it's OFF.
jec6613 Posted November 29, 2023 Posted November 29, 2023 I posted this in another thread, but what's always solved this for me is 1) restoring the device from the AC and 2) increasing the retries from the PLM. I also have an old power strip in the basement I keep my Christmas ones plugged into all year, and since doing that have experienced no issues.
Kentinada Posted November 29, 2023 Author Posted November 29, 2023 @jec6613 thanks. Can you tell me more on what you mean by "restoring the device from the AC"? Where do you increase the retries for the PLM? Can't find that in the Admin console.
Kentinada Posted November 29, 2023 Author Posted November 29, 2023 I found the Advanced/PLM Communication menu but these outdoor plugs don't support PLM Communication Settings.
Techman Posted November 29, 2023 Posted November 29, 2023 @Kentinada Your outdoor devices appear to be the older powerline only models. If you have a dual band plug-in module, try plugging into the circuit closest to your outdoor modules.
DennisC Posted November 30, 2023 Posted November 30, 2023 On 11/29/2023 at 5:03 PM, Kentinada said: restoring the device from the AC Expand When in the admin console, right click on the device and select restore device.
Kentinada Posted November 30, 2023 Author Posted November 30, 2023 (edited) OK, sorry for the late response. So these are the older, 2456S3E plugs. Would the newer 2634-222 units work better? Why? EDIT: Does the newer unit do power line AND RF signals where the old unit only does power line? Edited November 30, 2023 by Kentinada
Brian H Posted November 30, 2023 Posted November 30, 2023 The 2456S3E is the older designed. Power line only module. The 2634-222 is a dual band using both RF and power line signals. The dual band should work better. If their is another dual band module close enough to handle passing on the commands. If you have some power line noise. That could effect it working.
Techman Posted November 30, 2023 Posted November 30, 2023 @Kentinada I've attached the manual for your devices. Adding to what @Brian H said, a load plugged into the older 2456S3E can create noise on the powerline. The newer replacement, 2634-222 is currently available from Insteon and has updated firmware and is dual band. Outdoor On/Off Module – Insteon 2456S3E-en.pdfFetching info... 1
Kentinada Posted November 30, 2023 Author Posted November 30, 2023 Thanks. I ordered 2 new outdoor plugs today.
