Program Bug?
Program (with bug?) Not meeting time condition:
From Sunset + 15 minutes
To
3:30:00AM (next day)
Set Landscape Lights ON
Set Landscape Lights OFF
Program that works:
To
Sunrise - 2 hours (next day)
When I right click and select "Run If" (current time is 3:15ish PM) on the "bug program", it turns the lights on (they should not turn on because the IF condition is not met).
When I right click and select "Run If" (current time is 3:15ish PM) on the "works" program, the lights do not turn on (the IF condition is met).
I do not have 2 programs, I change the "To" to test the condition. Sunset to Sunrise works, Mix of Sunset to a time does not work correctly.
What am I doing wrong when the To is a time instead of sunrise?
Solved by Techman
Further testing, now the second condition of sunrise is also turning the lights on when the condition is outside the time frame.
It's now past sunset and they did not turn on. This program is the same as one for porch light which works. Any clues? Beuller?
Edit: Deleting and recreating the program fixed the problem. Thanks Techman! And thanks to everyone else that offered possible solutions. I appreciate your help!
Edited by nowandthen
Try deleting the program, then recreating it.
Also verify that the time is set correctly in the admin console
Program disbled?  ISY time not correct?
I have never experienced any probems with these type of programs (hard for me to imagine a bug).
If program is in a folder, make sure there is no condition on the folder.
When posting a program, right click the program and select copy to clipboard. This will allow you to post the program here, as actually written.
bgrubb1: Confirmed, I did click update then save changes. Thanks.
oberkc: EISY time is correct. Program is enabled. I have a nearly identical program that runs without issue. Thanks.
DennisC, Program folder has no conditions. Thanks for tip on posting a program:
Back Yard Malibu - [ID 0015][Parent 0014][Run At Startup]
        To       2:30:00AM (next day)
        Set 'Landscape Lights / Back Yard Malibu' On
        Set 'Landscape Lights / Back Yard Malibu' Off
I would second trying what @Techman suggested above. Sometimes programs get confused and you just need to start over.
I would suggest rebooting between deleting and recreating the program. Also, at least initially, use a slightly different program name.
Techman: I deleted and recreated the program. That did the trick.
To anyone, When creating the then condition, Action: Your devices, set [device/program,etc], when I select ON, there is an option below ON for 0% or 100%, my device is a v.38 OutletLinc, do I need to set it to 100%? It's currently still at 0% and program seems to work okay now.
I would have said "yes".  It is possible to have a device turn OFF when you send to it an ON command.  I would have said that setting the ON for 0% would be the way to do this.  If I understand you correctly, your device it turning ON even though it is set to 0%.  That is not what I would have expected.
I set it to 100% just to be sure.
Update on my original issue, the lights did not go off last night. Should have gone off at 2:30 AM but were still on at 3:30 AM. I double checked off time using UD App. It is set for 2:30 AM. I pressed "Save" in the upper right for the program and the lights went off. Hmmm... will see what happens tonight.
It worked last night. Maybe this is a clue for the programmers to look at. Save from desktop not saving? Save fro UD Mobile app seemed to set thing straight, or a coincidence. :) Thanks to everyone for your help!
