DavisWeather not populating Daily, Month, or Yearly Observations
Breezyken
Go to solution Solved by bpwwer,
I have installed the current DavisWeather poly (2.0.1), configured the settings, and loaded all the nodes.  However, only the current conditions from the console are displayed.  None of the observations data is being filled in.  I queried the server  with  https://api.weatherlink.com/v1/NoaaExt.json?user=<my Station ID>&pass=<my password>&apiToken=<my token>   and that returns ALL the data, including Daily, Month, and Yearly (But maybe not enough data to parse?).  My configuration parameters were copied directly from the node configuration and pasted into the URL.    Why is it not populating on the admin console?
My station is a Vantage Pro 2.  I don't have a solar radiation sensor.  I've attached the first part of the log, but the rest is just repetition of the parse error.  I also attached a sanitized response to the API call.
DavisWeather Debug Log.txt JSON Message.txt
Should be fixed in version 2.0.2.  Refresh the store to see the new version.
Thanks for reporting the issue.
      376.8k
