Shared Ring Device?
I just installed a Ring Stick Up Cam and the Ring Plug-in (node server).  In the Configuration section it says:
shared = Set to "true" to include shared Ring devices (Re-run device discovery after)
Is this talking about Shared Users within the Ring device?
This is for devices that are shared with you. If the new camera is in your same account then it should be found by the existing plugin setup. You might need to restart the plugin or query devices for it to discover newly installed devices. I haven't added new devices since having the plugin so don't fully know the process for updating to find new devices.
@Geddy this makes more sense.  Thanks.  I have not had any devices shared with me so I shouldn’t need this.
