VUE NS: Module not found
Hi @bpwwer, I tried to install the NS on a new eisy but I'm get this error:
2023-12-30 19:51:30,822 MainThread udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
  File "/var/polyglot/pg3/ns/0021b902658a_5/vue.py", line 10, in <module>
    import pyemvue
  File "/var/polyglot/pg3/ns/0021b902658a_5/pyemvue/__init__.py", line 2, in <module>
    from pyemvue.pyemvue import PyEmVue
  File "/var/polyglot/pg3/ns/0021b902658a_5/pyemvue/pyemvue.py", line 8, in <module>
    import boto3
ModuleNotFoundError: No module named 'boto3'
PG3x Version 3.2.17
Status: Connected
Frontend Version: 3.2.17
IoX Version: 5.7.1
Thank you
Solved by tazman
1 hour ago, tazman said:
Did you install the Developer Packege from the AC?
No I didn't.  Do I need it for this NS?  I don't recall needing to install it on my other eisy.
I know it did at one time. I don't know enough about the errors but I know some plugins require it and it won't hurt anything to give it a try.
I think you need to reinstall after you added the feveloper package for it to install properly.
