Setup Failed on Last Step
First, I have never received any response from Resideo Support regarding resetting my old password on the Honeywell Home Developer site.  So I decided to try using a new email address.  I created an account with my new email address (one I would only use for this purpose) and I got all the way through the node server installation instructions to the last step where it failed.
From the installation instructions on GitHub, both my thermostats show up, I click CONNECT and then it hangs and never gets to the point in the instructions below where it shows the User ID.  So I'm back to dead in the water with Honeywell Thermostats. Anyone else made it this far and farther?
I chatted with Resideo support. They can see my thermostats and the "ISY Node server HomeAutomation" app or integration. This particular support rep doesn't seem to think anything has changed on their end.
I wonder if the current problem lies with the authorization step. It asks you to specify "https://udi-honeywellhome-auth.azurewebsites.net/auth" as the authorization callback. This appears to be a website created by the original developer dbarentine 5 years ago. I wonder if it still functions? Sounds like this plugin needs to be brought up to newer standards and more tightly integrated with UD's oAuth and websocket infrastructures.
Still doesn't explain why resideo support is not responding to password reset requests, however.
Edited by Goose66
  • 5 months later...
No, I did not. I sold my Honeywell thermostats and replaced them with Ecobee.  Very happy with them. And they interface to the EISY though a plugin with no problem.
  • 3 months later...
Just tried and the authorization app on the azure server and it continues to not work as I expected from the instructions (no response, no userid).
  • 2 months later...
Finally found this post. Thank you oberkc and all. I have had the same problem/results. Does any one know how to get this flagged or removed from Polygot plugin store so others don't waste their time with this?
UPDATE:  replaced Honeywell Smart (?) thermostat with ecobee premium thermostat. On the expensive side of smart thermostats but received a $100 rebate from the utility company. Had a wiring issue during installation but ecobee has excellent customer service and actually corrected incorrect wiring of the old Honeywell thermostat. Polygot plugin installed easily with no issues. Highly recommend ecobee if you can justify the extra bucks.
I would say that there are tiers of products for smart thermostats and ecobee is very good value for the capability, quality, dependability and service as you mentioned. It's designed to be an home automation integrated product and I'm not as worried about them pulling the rug out from underneath my working system like Nest would have.
I bought mine from them as refurbished for $125 and it came with one remote sensor... in my experience that's good money for something that works.
Thanks paulbates....Completely agree... I payed $229 new w/remote sensor and after $100 rebate it was $129. As you eluded, it's well worth the money. It works on everything the first time out of the box and way more data than the old Honeywell. I'm very pleased with the purchase.
      378.2k
