PLM going bad?
I'm trying to edit some scenes in the admin console.  Everything looks good in the UI, it shows writing to devices, but when I fire the scene from an Insteon keypad it still brings up the unedited scene.  It's as if the devices aren't getting the updated scene info.
I've not run into this before, but I'm aware failing PLMs do odd things.  I'm wondering if this could be the PLM or if I'm missing something when it comes to editing a scene beyond level change -> update.
Thanks for any info.
Of course, sorry... ISY994 on 5.3.4
Button is definitely the scene controller.
It's the table and the downlights in this scene that I'm trying to set new values for.
If I fire from the KP button it goes to previous settings:Screenshot2024-01-10at19_17_56.thumb.png.631c582a830a8ceb1e3570cbe3987875.png
If I fire from the admin console it goes to the proper settings:Screenshot2024-01-10at19_18_10.thumb.png.868867a63eaf006c626593f6409df801.png
Have you tried the Event Viewer in level 3. When you try the changes in that Scene?
It will show the commands being sent and the responses from the module you are trying to modify. That may give you some helpful information. On did the changes actually get there and where accepted.
If the module you are trying to change the scene in. Is one of the older model modules. Some needed a power cycle of the module you changed to have the changes take place.
Edited by Brian H
Add data
