Kentinada Posted January 25 Share Posted January 25 I've read the older posts on 3-way wiring INSTEON switches and I think I get it but I don't want to mess this up. I will greatly appreciate your patience as I ask this. Please excuse the not great photos but I thought they helped. Here is Box A. It has: Line coming in (2nd from left) 1 Single pole switch (left most) 3 3-way switches (on the right) The 3-ways are all wired the same way which I'd hope they would be. The bottom right wire is from the hot pigtail. The top right wire (red) traveler wire. The bottom left wire (black) traveler wire. White goes to white pigtail. Here is Box B (just one example of one). The traveler incoming wires go to: red to lower left terminal on switch black to upper right terminal on switch white common tied to the common going to the light The bottom right black (load) wire goes to the light. So from another thread I read here, I copied this below and I hope have it right for my situation. This is what I need confirmed or changed. (All 3 of the 3-way switches are the same so it shouldn't matter which one I do as long as I match it to the right Box B.) So the resulting wiring in Box A looks like this: 2477D black wire ties into black wire pigtail 2477D white wire ties into white wire pigtail 2477D red wire is capped Red traveler wire in Box A is capped And in Box B: 2477D black wire tied to traveler black wire 2477D red wire tied to black wire going to light fixture 2477D white wire tied to white wire going to light fixture Red traveler wire coming into Box B is capped Does this make sense? Correct? If not, what changes? Thanks so much for the help in advance. I've always gotten great support from this group. Link to comment Share on other sites More sharing options...
Kentinada Posted January 25 Author Share Posted January 25 Well I double checked against this diagram and went ahead it with. All is well and working with a dual controller scene. 1 Link to comment Share on other sites More sharing options...
dbwarner5 Posted January 25 Share Posted January 25 Once you do a few, they become more second nature. Glad you figured it out! Link to comment Share on other sites More sharing options...
